Good and Bad Years?
Good and Bad Years?
Are there any good or bad years for the diesel motors, or anywhere else, in the F250's and F350's? I'm looking mainly at the '08's, or higher if I it's a good price. But if I can find a nice '06 or '07 for a lot cheaper I may consider going that route. But I'm hearing that there are some bad years. If this is true, which years are good and which are bad?
Which diesel forum? I posted this over on The Diesel Garage too.
Are there problems with the 6.4's? The 08+ body styles are definitely my favorite, but I don't really wanna buy problems either.
Problems? Not wide spread. But they dont get very good mileage. I like the interior of the 08-10 best, but the 6.4 just doesnt grab my attention. A 6.7 isnt much more expensive, and at least with a 6.7 you get decent mileage and a lot of power.
I have the 6.4. It is a pretty good motor.
Most of the issues do center around the mpg's. This is a heavy truck coming in at 8K or more for most people. Combine that with the emissions and it can be an issue.
Alot centers around what your use would be. This motor works great for towing and long distance applications. This is where it shines the most and will do the best service with the fewest problems.
Just running to the store or a lot of city driving and then you will have some issues with the EGR or the DPF.
So the real question is what would you use the truck for?
Problem areas for this motor can be the radiator seams, not ever an outright failure or any thing to leave you stranded, rather a slow leak. Seems to be a problem for the 6.7 as well. Cheap design.
EGR valve...they did come out with a redesign so you don't see too much of that anymore.
DPF. The DPF traps soot which has to be burned off from time to time. Slow speeds/city stop and go do not work well with this.
on
Heard the same from folks around here - the 6.4 & 6.7 don't like stop 'n' go driving. Better off work'n them hard all the time - they seem to do better when they're run that way. That's what worries us - our app (farming) works'em pretty hard but includes quite a bit more idle - low speed ops than most. Granted they're loaded but we might only be going 10mph. Worried we wouldn't regen enough and have issues.
I have a 2003 6.0 that I bought new now with 145,000. I did have some problems innitially, egr sensor, wires chaffing, an oil leak, and one failed injector. Since all that has been repaired I am really pretty happy with the truck. It seems all these trucks have some issues so pick your poison. the mechanic that works on my truck seems to think the 6.0 is one of the better ones to go with. These are expensive trucks to own and operate but so far I am hanging in with it. Truck seems to get a consistant 15 mpg.
One thing that I would plan on doing.
