Old 10-21-2014, 08:07 PM
How-Tos on this Topic
Last edit by: IB Cristina
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
Print Wikipost
TPMS - low tire pressure light will not go away
Old 12-10-2014, 09:17 AM
djousma's Avatar
djousma
djousma is offline
Originally Posted by wtrlogd
I had my dealer set all 4 positions to the minimum setting, believe he said 50psi was as low as the IDS software would let him set the BCM settings to. I haven't rotated tires yet, hopefully, he did what he said he did, and I'll be able to avoid the training process when I do rotate. With the empty truck I've been running 65psi front and 55psi rear, no idiot light on the dash.
Ditto. I had my dealer do the same, although 55lbs all the way around. No need to worry about retraining the location anymore. I typically run 65 in all 4 unless I am hauling/towing heavy.
Note that not all dealers will do this, mine made me sign a release form.
  #32
Old 03-04-2015, 11:39 AM
rbtom's Avatar
rbtom
rbtom is offline
I haven't had a bit of trouble with mine (YET!), and the more I read but this, the more I shake my head and really wonder! sensors everywhere, for everything!
Why couldn't you drill 4 holes in a lawn mower wheel, install all of the TPMS sensors, (that are prone to nothing but failure, headaches, and money), air it up to the proper pressure, throw it in the back of your truck and just be done with it??
Just my rant,
Tom
  #33
Old 09-24-2015, 11:36 AM
graphite1326's Avatar
graphite1326
graphite1326 is offline
no horn
Originally Posted by Champ198
The same thing happened to me a while back. You will need to run the TPMS reset procedure as outlined in the manual. It's not hard but you have to run around to each tire and release air as per the procedure. You should be fine after that. (I copied and pasted the procedure from the manual)
The TPMS reset procedure needs to be performed after each tire
rotation on vehicles that require different recommended tire
pressures in the front tires as compared to the rear tires.
WARNING: To determine the required pressure(s) for your
vehicle, refer to the Safety Compliance Certification Label or
Tire Label located on the B-Pillar or the edge of the driver’s door. See
Vehicle loading - with and without a trailer in this chapter for more
information.
Overview
To provide the vehicle’s load carrying capability, some vehicles require
different recommended tire pressures in the front tires as compared to
the rear tires. The tire pressure monitoring system (TPMS) equipped on
these vehicles is designed to illuminate the low tire pressure warning
light at two different pressures; one for the front tires and one for the
rear tires.
Since tires need to be rotated to provide consistent performance and
maximum tire life, the tire pressure monitoring system needs to know
when the tires are rotated to determine which set of tires are on the
front and which are on the rear. With this information, the system can
detect and properly warn of low tire pressures.
TPMS reset tips:
• To reduce the chances of interference from another vehicle, the TPMS
reset procedure should be performed at least three feet (one meter)
away from another Ford Motor Company vehicle undergoing the TPMS
reset procedure at the same time.
• Do not wait more than two minutes between resetting each tire sensor
or the system will time-out and the entire procedure will have to be
repeated on all four wheels.
• A double horn chirp indicates the need to repeat the procedure.
Performing the TPMS reset procedure
It is recommended that you read the entire procedure before attempting.
1. Drive the vehicle above 20 mph (32 km/h) for at least two minutes
and then park in a safe location where you can easily get to all four tires
and have access to an air pump.
2. Place the ignition in the off position and keep the key in the ignition.
Tires, Wheels and Loading
3. Cycle the ignition to the on
position with the engine off.
4. Turn the hazard flashers on then
off three times. This must be
accomplished within 10 seconds.
If the reset mode has been entered successfully, the horn will sound
once, the TPMS indicator will flash and the message center (if
equipped) will display TRAIN LEFT FRONT TIRE. If this does not
occur, please try again starting at Step 2.
If after repeated attempts to enter the reset mode, the horn does not
sound, the TPMS indicator does not flash and the message center (if
equipped) does not display TRAIN LEFT FRONT TIRE, seek service
from your authorized dealer.
5. Train the TPMS sensors in the tires using the following TPMS reset
sequence starting with the left front tire in the following clockwise
order:
• Left front (Driver’s side front tire)
• Right front (Passenger’s side front tire)
• Right rear (Passenger’s side rear tire)
• Left rear (Driver’s side rear tire)
6. Remove the valve cap from the valve stem on the left front tire;
decrease the air pressure until the horn sounds.
Note: The single horn chirp confirms that the sensor identification code
has been learned by the module for this position. If a double horn is
heard, the reset procedure was unsuccessful, and must be repeated.
7. Remove the valve cap from the valve stem on the right front tire;
8. Remove the valve cap from the valve stem on the right rear tire;
9. Remove the valve cap from the valve stem on the left rear tire;
Training is complete after the horn sounds for the last tire trained
(driver’s side rear tire), the TPMS indicator stops flashing, and the
message center (if equipped) displays:
TRAINING COMPLETE.
10. Turn the ignition off. If two short horn beeps are heard, the reset
procedure was unsuccessful and must be repeated.
If after repeating the procedure and two short beeps are heard when the
ignition is turned to off, seek assistance from your authorized dealer.
11. Set all four tires to the recommended air pressure as indicated on
the Safety Compliance Certification Label or Tire Label located on the
B-Pillar or the edge of the driver’s door. See Vehicle loading - with and
without a trailer in this chapter for more information.
I tried this and the horn never sounded on my left front. I started over and just went to the front right and it sounded. But that doesn't help me much. Started over again and tried the front left and still no horn. Bad sensor?
  #34
Old 11-15-2015, 10:56 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
Ancient thread but still worth a look plus a bump back for a current read for others.
For whatever reason, last year I was fine with lower pressure 55 front/65 rear. This year and after rotating the tires, didn't work so now I have 80 in the front and 65 rear .... and the retrain tool winging its way to me. I'll set all four at 55-60 and as I have for many years, not worry as I check my tire pressure pretty regularly - it's just the fast leak on the road that will then give me a warning. There are instructions on eBay on how to use that retrain tool though mine is coming from another, less shipping time delay and possible a bit less expensive source (Amazon)
FX44AU
2017+ Super Duty
44
03-29-2024 08:02 PM
ctfl
1999 to 2016 Super Duty
04-26-2018 10:03 PM
leafswin
Escape & Escape Hybrid
12-16-2014 01:29 PM
ExpyBob
1997-2006 Expedition & Navigator
04-09-2006 01:11 PM
raudy
24
03-12-2004 06:13 PM
Quick Reply: TPMS - low tire pressure light will not go away
