I have a 1992 F-250, 460ci and the tach reads "0" with key on before starting. Immediately upon starting the Tach reads 2500 and stays there
never moves.
Any ideas would be greatly appreciated.
Roger
Well if the distributor was messed up I doubt it would run
It could be the gauge itself has failed or maybe wiring
My tach is aftermarket so I'm not sure how the factory is wired but mine is wired to the negative of the coil
It obviously has power since it moves. But it's not getting signal
