Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > California, Southern Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
California, Southern Chapter Join Chapter, Leader: wpnaes
  #1 (permalink)
Old 10-16-2011, 11:13 PM
sand_fiend's Avatar
sand_fiend sand_fiend is offline
Garage is empty, add now
sand_fiend has a good reputation on FTE.sand_fiend has a good reputation on FTE.
Sandfiend
after market exhaust ??
Ok guys in so cal.
Im looking to put an exhaust on my truck soon.
I hear that if you mod the exhaust in so cal it will not pass smog inspection. ?
I know they are starting to smog our trucks. my best friend who lives in Bakersfield got a smog inspection at test only center on his last registration.
03 250 7.3.
fortunately his truck is all stock and he had just finished a complete long block.
i know i can keep my old exhaust and put it back on for inspection if or when my time comes. i dont want to go hog wild on the exhaust, just something that will help the motor a little.
do i need a full exhaust ??
whats your thoughts
__________________
Phil, 02 F250 7.3, Auto SD 4X4 shortbed.
149k miles. 373's.Glowshift Boost, Egt and Trans Temp Gauges.Wix 6637 Airfilter. MBRP 4" Turbo Back Exhaust.DP Tuner- 60T, Decel, 80E, 60E,
A.E. Ford Bundle.
  #2 (permalink)
Old 10-16-2011, 11:32 PM
DieselHardware's Avatar
DieselHardware DieselHardware is offline
1999 Ford F-250
DieselHardware has a good reputation on FTE.DieselHardware has a good reputation on FTE.DieselHardware has a good reputation on FTE.
The only concern would be if you have a catalytic converter or not. IIRC you shouldn't have a cat on your truck. Take a look underneath just to make sure. If you don't have a cat, then you can pretty much do whatever you want. If you have a cat, then you will have to reinstall it before smog inspection.
  #3 (permalink)
Old 10-16-2011, 11:49 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is online now
9 ECHO 1
2002 Ford F-250
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
You can modify your exhaust and be just fine with SMOG. Some 7.3s came with a catalytic converter. If yous does you will need to keep it. Other wise you may do what ever you want to it (SMOG wise..).
However, if your exhaust is too loud (hard to do on a truck with a turbo) or if you dont have a muffler, you can get a ticket. But that will not fail you on a SMOG. All SMOG does is check for emissions standards, and as of right now (just tested earlier this year) very little testing is being done. They check for check engine lights, excessive smoke on acceleration, and "obvious modifications to the emissions systems." So with an exhaust system you're safe.
__________________
- Trey PAA Member #110
"Jaws"- 2002 F250 XLT CrewCab Short Bed 4x4 7.3L
My Mods Thread - My Superduty videos
SoCal Chapter Member (Join us HERE)
  #4 (permalink)
Old 10-17-2011, 01:39 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.orng1 has a good reputation on FTE.
Like they said only thing to worry about is if it has a cat. If it doesn't you're good.
Tags
2011, 250, 73, 73catalyticconverter, aftet, aftrr, exchaust, exhaust, f150, ford, forumd, market
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
