How to prevent rust on rear shackle bracket?
It seems that water and rust will collect in the depression of the rear shackle brackets on these trucks.
I just wire bushed the rust away and repainted mine. But it seems that water will collect in the depression of the shackle brackets naturally and cause more rust.
Has anyone drilled a drain hole in the center of the depression to let the water drain? Or would coating the depression with water resistance grease be a good idea?
How do you all prevent rust in the rear shackle brackerts on these trucks? They don't look like a fun thing to remove and replace.
Commander_Chaos
11-19-2013 01:02 PM
JimG1098
10-27-2009 02:44 PM
