Question about Kenne Bell on a 5.0 Fullsize Bronco
Old 10-15-2011, 10:08 AM
bafm's Avatar
bafm
bafm is offline
I'm putting together parts to put a KB 2.1 blower on a new 347 build in my 1990 bronco.
The truck is locked down at the mechanics for the weekend and it's been there for several months and I've forgotten a few things about it but I need to find some info.
First, can someone tell me if the 1990 Broncos and/or F150's used a serpentine belt system or not?
Secondly, I need to know the stock crankshaft pulley diameter measured across at the top of the ribs, (assuming it is a serpentine belt system).
If it's not, what's the best way to convert it over to a serpentine belt system? What conversion system to use, Explorer 5.0, aftermarket, or what?
Any advise is apreciated.
Old 10-15-2011, 10:25 AM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
If it has 4-5 ribs...Its a serpentine setup...
Old 10-15-2011, 10:55 AM
bafm's Avatar
bafm
bafm is offline
LOL, Yeah, I know.
I just can't get to it right now to look at it and I'm trying to finalize a deal on some parts.
Old 10-15-2011, 11:16 AM
kentuckyredneck's Avatar
kentuckyredneck
kentuckyredneck is offline
I'm almost positive all fuel-injected trucks had serpentine belts...
Old 10-17-2011, 04:31 PM
bafm's Avatar
bafm
bafm is offline
Just an update, I went by and measured it today. For general knowledge, it's got a 6.5" 6 rib serpentine pulley.
Old 10-17-2011, 04:37 PM
86F150302's Avatar
86F150302
86F150302 is offline
Nope. My 86 was V belt EFI.
6 rib belts..
Old 10-18-2011, 11:13 AM
kentuckyredneck
6 rib belts..
That's a 7th gen. I didn't consider that one. Should all be serpentine after '87 then.
Old 10-18-2011, 12:13 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
so you converting to mass air and going to get a dyno tune or are you using a megasquirt or tweecer?
Old 10-18-2011, 01:17 PM
bafm's Avatar
bafm
bafm is offline
It's already converted to mass air. One little quirk is I installed the Mass Air conversion when the truck still had a manual, and shortly after the conversion I switched to an auto tranny and it never really idled right with the auto, but from what I've learned the puter will still work once it is reprogrammed.
I'm still undecided about what tune to go with. The PMS or a custom tune seems like the best option since I really don't have the time or the desire to totally learn the different programs like on the Moates QH or Tweecer. The SCT 4 also looks ok so long as I can get it preprogrammed.
In other words, I'm pretty new to the tuning options game and am open to suggestions.
Old 10-18-2011, 04:57 PM
Kemicalburns
what auto are you running and what efi system? is it out of a mustang for instance?
Old 10-19-2011, 05:43 AM
bafm's Avatar
bafm
bafm is offline
It has a Motorsport conversion. I'm pretty sure that kit used the same mass air computer that they put in the Mustangs, an A9L if I'm not mistaking.
Servando Abm Almaraz
1978 - 1996 Big Bronco
02-04-2015 04:12 AM
tex4431
10-03-2009 05:56 PM
80Bronco94
01-31-2005 05:36 PM
miketampa
01-24-2003 03:23 PM
Quick Reply: Question about Kenne Bell on a 5.0 Fullsize Bronco
