Fender well exit header pics. wanted
Nick on a old 74 f150 4x4 I had I ran L&L fenderwell headers
but I do not have any pics so I will describe the set up best I can.
the exhaust pipe was bent back towards the inside of the frame
and up to the mufflers that where in there normal position then out to the tail pipes. The truck was High enough that I never had any pipe crushing problems. Eric
Here are some pics masterbeavis posted of his L&L headers and exhaust.
http://community.webshots.com/photo/...55126503pPvQtZ
http://community.webshots.com/photo/...51294108pkVnun
http://community.webshots.com/photo/...68959387uZzfdR
Another option for exhaust I've been mulling over for the fenderwells is running the pipes down the sides then have them bent up, through, down, and out the back of the rear wheelwells. Using this method the pipes are visible in the wheelwell because if installed properly, the pipes will be arched up almost all the way to the bottom of the well.
I've seen this on a couple of 4X4s but both had at least 6" of lift. I think the lift would be needed so the pipes don't interfere with the tires.
kyle1979ford
44
07-31-2011 07:39 PM
CanadianBigBlue460
13
08-01-2010 10:23 PM
Ranger1F150
05-18-2007 04:22 PM
