Injector differences?
I have an 08 superduty with the 3v 5.4. The truck had high miles when I bought it, so I decided to put a set of injectors in it. Me being tight like I am I ordered some off ebay that were take outs from a place that does propane conversions on new trucks. The ones I bought were part ## 9C2E-A5A , 8556V, 0 280 158 193. They went in fine, and run fine. But after re-reading my auction, I noticed that they were for trucks built after mine, sometime in 08. Where mine was built 11/07. The injectors that were in it are stamped # 7c3e-ab 0 280 158 138 7-14-02-07-114234 The new injectors run MUCH better, and the comp says I'm getting better mileage, but when I was hooking up my trailer it smells pretty gassy at idle. No codes, no complaints. But does anyone know what the diffeerence between the injectors is?
Assuming injectors physically fit your application and mate up properly they'll differ in the amount of fuel per hour delivered. I myself don't know enough about the OBD II funtion whether it would detect an issue with too much fuel. Perhaps it doesn't at this point which is why no codes are indicated.
Someone more knowledgeable will certainly come along and answer this much better----soon I hope!
They aren't too much different of you would have a CEL (check engine light ) lit for the mixture being too far off. These are pretty sensitive to this due to the chokehold of the EPA. The part number often changes with different model years even if the part doesn't actually change.
Are they the same color?
If it is rich from just an injector change, then they may be a larger lb/hr and when the PCM is set for the stock lb/hr, the injector pulse will inject more fuel than the stock injector and will cause a over rich condition, but it is usually enough to throw codes on these tight tolerance PCM tables used today.
I will try to see if I can contact numberdummy to see if he can give a correct answer on the part numbers.
The OP has listed the ID engineering prefix & suffix (9C2E-A5A) (7C3E-AB) found on the parts themselves. These are not Ford part number prefixes & suffixes.
Since I have no Master Cross Reference Catalog after 2001, there's nothing I can do...sorry.
If the actual Ford part numbers were listed, I could find the applications by using the Ford Dealer Part Locator System and/or PartsGuyEd's website.
Here is an example of an ID engineering number prefix 7C3E and suffix AB
Since I have no Ford parts catalogs after 2001, there is nothing I can do.
The only way you're going to get the actual Ford part number from this prefix/suffix, is from a FoMoCo dealer.
