Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 10-13-2011, 06:16 PM
Scout Pilot's Avatar
Scout Pilot Scout Pilot is offline
1962 Ford F-100
Scout Pilot is starting off with a positive reputation.
Arrow Some newbie tips?
I recently bought a '62 with a 292 2 bbl. Since winter is almost here, I am about to begin my engine touch up. This is my first real solo non deisel engine project. I have a few questions for you experienced guys.
This engine has quite a bit of old debris (grease, dirt) and paint. If I tear it down to main components (manifold, heads, block) and ball blast it, do I risk any unreparable damage?
After I clean it, I plan to high temp paint it. I am thinking silver or ford blue. Any suggestions?
Has anyone ever used exhaust manifold wraps?
I thank everyone in advance for helping out a newbie.
  #2 (permalink)
Old 10-17-2011, 10:40 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Stock color is gloss black block, heads and intake and old ford red on the valve covers. The air cleaner is semi gloss black. I would not recommend bead blasting as it gets everywhere. The Y will clean up with brushed and cleaner. Eastwood makes a really nice engine cleaning/paint kit with a high solids brush on paint. This paint works really well.
Do not wrap the y block manifold or crossover pipe. It needs to bleed off the BTUs. the Y has sodium filled exhaust valves and wrapping will keep the heat in on shutdown.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #3 (permalink)
Old 10-18-2011, 06:58 AM
1962 Ford F-100
Thanks for the info Garbz. I appreciate it. Feel free to post anything else that may help.
  #4 (permalink)
Old 11-08-2011, 09:27 PM
1962 Ford F-100
Ok....stripping paint off this engine is not going smoothly at all...
Anybody have any tips? DO I get a wire bit for a drill?
  #5 (permalink)
Old 11-08-2011, 10:06 PM
turbohunter's Avatar
turbohunter turbohunter is offline
1963 Ford Thunderbird
My Garage
turbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to beholdturbohunter is a splendid one to behold
Just found the thread.
Congrats on buying the new piece.
Yeah what your doing is a bitch, there's no two ways around it.
Go have a beer when you get pissed.
I'm assuming you are leaving the engine in the truck to clean.
Yanking the exhaust will make it a little more accessible. Of course block the exhaust ports with rags or........
Wire wheels will help.
It's hard work but it will give more satisfaction to you and value to others when done.
It's worthwhile, keep after it.
Good luck.
__________________
'08 Super Duty 6.4, '61 Unibody, '63 T-bird, '66 Mustang
'76 F750 Firetruck, '83 F150, '74 F-1004x4 shrtbx
And not enough time to drive 'em.
Marc
  #6 (permalink)
Old 11-09-2011, 01:38 AM
Buzz44's Avatar
Buzz44 Buzz44 is offline
Garage is empty, add now
Buzz44 is gaining momentum as a positive member of FTE.Buzz44 is gaining momentum as a positive member of FTE.
I use wood chisles in various sizes to scrape alot of the real deep grease off followed by drill with various size wire wheels. Next spray down with oven cleaner and let sit for a good long while. If still not to your liking repeat the oven cleaner again. Final is wire brush loose paint and grease then paint.
This
Click the image to open in full size.
with some patience and elbow grease (not the same grease you will be cleaning off) will look like this
After this cleaning some engine paint leads to this.
Finally installed
Again be patience and use alot of elbow grease. Rustoleum engine paints used for the engine block. Valve covers are just a gold standard rustoleum paint.
Good luck with your clean up. Post up some pics of how it turns out.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Vic by the way.
  #7 (permalink)
Old 11-09-2011, 11:13 AM
1962 Ford F-100
Marc and Vic,
Thanks for the pointers. I am trying to do it by leaving the block in but I am starting to feel that if I am going to do this right I am going to have to pull it.
Marc, There have been a few times already where I have had to walk away for a bit due to bruised feeling and knuckles (and a little blood).
Vic, were you able to pulled the motor cleanly by just removing the the left front fender? I dont have alot of room in my garage so I would have to do it efficiently. Did you use a primer before you painted it?
Thanks.
Adam
  #8 (permalink)
Old 11-09-2011, 11:37 AM
My Garage
Adam
If you do pull it, be sure to watch out for one very important thing.
It's very important to have a plan in mind so that you don't succumb to the idea of "well as long as I did that I may as well do this too!". This can lead to disappointment and a pile of parts in your driveway.
What is your time frame? How much room do you have? How much money do you have? How important is it to drive?
I have made almost every mistake there is related to restoring.
Don't get discouraged whatever you do. Hanging out on FTE is very helpful with that.
Have fun!!!!!!!!
And take some pictures and post them like Vic did. We all love that.
__________________
Marc
  #9 (permalink)
Old 11-09-2011, 02:30 PM
Buzz44's Avatar
Quote:
Originally Posted by Scout Pilot View Post
Marc and Vic,
Thanks.
Adam
Adam I did not prime the motor before paint. I dont know of a hiheat primer. The front clip was completely off of the truck. I do believe it could be done with the motor still in the truck but it would be a tuffer job motor in truck. Also this was an engine I had on a stand and it was summer time. I did the cleaning in my driveway in warm weather. I dont think I would attempt this outside in colder winter weather. I agree have a plan if and when you do this. If pulling the motor I would take the time to clean front frame as it would all be exposed at that time. If you remove the front clip to do this I would stick to just the areas easy to clean an then reassemble. Is this a driver or complete restore? You will have to make those choises. Frustration does set in when I think things are not moving fast enough. Sometimes I have to step back get a beer or cup of coffee and take a think about this realize its a hobby not a job and then go from there. If you check my build down in the projects forum you will see what I started with and see my plan for this truck. Suffice to say it is a project driver with a little overkill as turbohunter says dont get carried away. I did a few times.
__________________
Vic by the way.
  #10 (permalink)
Old 11-19-2011, 01:14 PM
64blue's Avatar
64blue 64blue is offline
1961 Ford F-100
64blue is starting off with a positive reputation.
Block color
Check out this fellows page. He has all kind of good info about your y block
http://www.y-block.info/enginecolor.html
  #11 (permalink)
Old 12-01-2011, 06:27 PM
1962 Ford F-100
Quote:
Y-Block Info
Thanks. I just got back from vacation and am ready for some greasey dirt.
  #12 (permalink)
Old 12-01-2011, 09:42 PM
My Garage
In case you haven't found it yet here is a great site for Y block info.
John helped me a great deal in my rebuild. I highly recommend him and his stuff.
FORD Y
__________________
Marc
  #13 (permalink)
Old 12-05-2011, 09:45 PM
1962 Ford F-100
I already had it bookmarked. I will definately be ordering from him.
  #14 (permalink)
Old 08-12-2012, 07:00 PM
1962 Ford F-100
http://www.ford-trucks.com/forums/pi...ctureid=106865
Sorry it took so long to get a picture up, I have been to busy driving it.
  #15 (permalink)
Old 08-12-2012, 07:04 PM
1962 Ford F-100
Tags
1963, 292, block, f100, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
