351w efi to 351 carb
hello guys i am taking my efi 351w out i have changed everything on it under the hood and it still isn't running correctly. so i am going carb the truck isn't run that much but i want it to run right when i need it so carb is much easier to work with for me. i plan on getting a 84 351w carb and swapping it in for the efi what will i need to do. i plan on using the entire motor from the 84 and not needing the ecu/pcm at all. what will i need to do for the ignition and alt? as for fuel i plan on using the current set up with a regulator to cut it down to 7psi to 9psi. i do not want to remove the entire fuel system and tank to put in the truck. so is a option just hooking the fuel delievery up to the carb without using the mech fuel pump on the block? if so what do i do with the pump on the block? or do i use it and put the regulator between the pump and carb? ok as you can see i have a lot of questions and thanks for all the help guys.
Tom
Tom
JackWStafford
09-01-2018 07:36 PM
nerdpcr
07-13-2014 10:41 PM
sacf250
01-04-2005 05:50 PM
