1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Vacuum seals & dust boots w/ pics
Old 10-12-2011, 05:44 PM
Special Ed's Avatar
Special Ed
Special Ed is offline
Just picked up my truck from the dealer. They changed out the vacuum seals & dust boots. Wondering why one side looks different than the other. One side has rubber hanging all out & the other naked no rubber. Can anyone help me out with these pics? Thanks.
Old 10-13-2011, 06:39 AM
Special Ed's Avatar
Special Ed
A bump for a new day
Old 10-13-2011, 06:58 AM
wulfman's Avatar
wulfman
wulfman is offline
Hey Ed try this in the superduty section they are real helpful up there with this sort of thing ,sense it not 6.0 engine related.
Old 10-13-2011, 07:14 AM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
Both of my seals are out of place on my truck.
Old 10-13-2011, 07:21 AM
Special Ed's Avatar
Special Ed
Appreciate it wolf & 2006. Yes your right, dont know why I posted that here. So use to 6.0 section I guess. Can I get a mod to move this for me please?
Old 10-13-2011, 07:49 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
Moved to Super Duty forum
Old 10-13-2011, 07:55 AM
Kep4's Avatar
Kep4
Kep4 is offline
Jäger
They either used two different seals, or they didn't replace one of them. The metal seal (bottom pic) looks exactly like the factory and replacement version that was on my '05.
Old 10-13-2011, 12:51 PM
Special Ed's Avatar
Special Ed
Thanks Kep. Thinking of going back to the dealer today & asking them about it.
Old 10-14-2011, 09:04 PM
Special Ed's Avatar
Special Ed
So the passenger side (one with the rubber) been leaking fluid since I got this done at the dealer. Checked my diff & it is low on fluid. Any idea whats going on here?
Old 10-14-2011, 09:11 PM
xd2200's Avatar
xd2200
xd2200 is offline
Oil leaking past seal at differential. Could be bad seal or clogged axle vent line. Latter probably more common so check it first.
Old 10-14-2011, 09:20 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
most likely they cut the seal sliding the axle back in, very big project to fix this i might add. when i did my 2004 F350 i had a little gear oil come out but that was it, yours is actually leaking bad, tell them why they installed different seals and to fix your axle seal now.
Old 10-14-2011, 09:22 PM
SuperDutyScaler
**** like this is the reason why I do all my own work! Dealers have young kids who dont give two pennies about your truck that you bust your *** to pay for! They would run a truck into a wall if they could get away with it and not even care
Old 10-14-2011, 09:34 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Dust seal wont leak oil on its own. If you are leaking oil its an inner axle seal. Mine is leaking too..
Old 10-14-2011, 09:42 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Looks like they caused the problem if it wasn't leaking before. You have to have a lite touch when installing the axle through the seal...The diff has to come out to replace the seals which means both sides need to come back out..Bummer.
Old 10-15-2011, 06:21 PM
Special Ed's Avatar
Special Ed
Appreciate all the responses. I usually do all my own work but originally brought it in for a fan clutch that my extended warranty was covering. They found the bad dust seals & vacuum seals which the warranty also took care of. Yes it was not leaking a drop before I brought it there. I did notice it wet when I picked up the truck & asked them about it. Tech told me fluid filled the tube when he pulled the axle & it may leak for a few days. Also my Mag-Hytec diff cover didn't help him out either with the extra fluid. He stated the Mag-Hytec cover keeps the fluid level higher than with the stock cover. I wasnt sure how correct he was on that statement but I wasnt for sure so I didnt comment. Regardless, its leaking & everytime I park it looks as the same pictured. If the seal is indeed damaged I sure hope they don't try to give me the shaft instead of a new seal.
Quick Reply: Vacuum seals & dust boots w/ pics
