Rear end locker?? Anyone have one??
Hey guys? I was hoping someone could shine some light on these things for me. My truck is 2wd, and I recently moved to northern Alberta where it's snow 5 months out of the year, will a rear end locker work to my advantage? Any one use one in the snow? Thanks
Grant
Grant
I would be hesitant to run a locker any where that ice is an occurring thing! I have been on ice with a tru-trac once and an old Detroit locker a couple of times! That cured me quick! They swapped ends on me ^so fast I didn't remember which way I started! I'll stick with a good limited slip for my snow truck it's predictable! Granted I don't drive in it all the time ^so maybe someone else has better experiences! ^so I'll let them talk...
Jim & fat Monty
Jim & fat Monty
Good snow tires will be the best thing you can do for yourself.
And since you're on here asking about this and have a 2wd I'm going to assume you are heading there from somewhere less snowy.
I highly suggest some type of undercoating on your truck, like Fluid Film, before winter starts to help keep some of the rust away. You can't prevent it 100% but you can minimize the damage.
Stewart
My dually has the spicer 80,4:10 LS....and its a scary ride on ice...and a couple inches of snow required 4x4. It's great for leaving 4 black stripes on a dry road....but crappy on everything else, a slight rain and I can donut it easily. Hopefully it'll wear out soon and I can drive normally. I vote quality snow tires
I have grown up and spent most of my life in the mud and snow. Whether for fun or for work, Tires are where to start, all the high tech stuff may help some but in the end if you cant get the power onto the road then you're just spinnin yer wheels.
Skinny tires work better for the snow, wide tires for the mud.
Hope that helps.
AJ
Hope that helps.
AJ
AJ
Yea I moved here from Vancouver island, only snows there 3 time a year. I'm not so much worried about ice as I am about getting stuck getting out of my back ally and onto the plowed roads.. Thanks 7.3 Rocket, I'll look into that, isn't fluid film just lube? I was thinkin about throwin a coat of rubberized undercoat under her.
The new all terrain design is so-so in the snow, the older ones are better. Anything with deep spaced out treads is good, and x2 yes thin is better. I've lived in Massachusetts my whole life and had a 2wd 85 GMC 1500 for my first vehicle, no lockers, no abs, no power windows, you get the picture. I found that the best thing to do is put as much weight as you can in the bed. I don't mean fill it to the brim with sand, but add a good 600 lbs of bricks, CMU, sand, etc. I used to put a 2x10 scaffold plank up against my wheel well and fill from that to the tailgate with bricks.
Lockers would be nice, but I'm 50/50 on having a permanently locked rear. You'll really only need it some of the time, but mostly you wont. Granted it would be great to have when you need it, but I still don't think that outweighs having to deal with it all the time.
Your best path is good tires, a lot of weight above your rear wheels, and skilled light foot driving.
Edit: Carry the gear to get unstuck too. If you do get stuck, don't dig yourself deep. The earlier you quit the smaller the vehicle/crew that can get you out. I still carry a short shovel, grippy 2x10, and chain. Back in the day I'd carry a floor mat or piece of carpet too, something that will grip the tire and ground if you stick it under a tire
I dont have many problems any more, and yes....your truck will rust faster than you will believe. 1 winter with salty roads is like 10 years anywhere else.
