Turbo?
Turbo?
I've got my truck down for turbo cleaning, EGR delete and an oil cooler. I disassembled the turbo and the unison ring was frozen to the center section. I had to soak it in PB Blaster and pry it off. The unison ring looks pretty good, but the center setion has a lot of scale and rust. Removing the rust with a wire brush still doesn't allow the unison ring to rotate. How aggresive can I get with removing the rust or do I need to replace the turbo?
Thanks!!
Thanks!!
When i cleaned mine it wasn't frozen on but close ,the cleaning instructions say scotch brite pads which i used but i also used light sanding dics to remove the heavy stuff. Mine was pitted very bad got mostly clean but pits were still there. When you put it back together use a high temp antisieze not a lot just lightly on U ring and viens where they sit on ring.
BryanStein
10-21-2014 08:44 AM
