2011 f-250 no driveshaft carrier bearing??
Ok, so I was looking into the 4" lift blocks to replace my 2" stock ones to lift the rear up a bit and was looking to get a carrier bearing spacer but when I looked up at the output shaft from the trans, there is no carrier bearing at all.
Question: (1) when did they stop putting in carrier bearings and (2) if I use these modest lift blocks, will I have a problem or is the lift small enough not to matter to my driveline? Thanks in advance folks,,,
Yeah, no need for a carrier bearing since the shaft is so short. It's actually short enough that you should look into either factory tapered blocks, or a bolt in wedge to lift the pinion angle and keep the rear axle in line with the d-shaft. I ran flat 4" blocks, but the pinion angle wasn't ideal.
I was looking into these:
ReadyLift 2011 Ford F250 Super Duty 4" Rear Lift Block Kit
They don't say anything about being tapered but are f250 specific installation. readylift makes good stuff too from what I hear.
These are axle shims:
http://www.4wheelparts.com/Lift-Kits...=101&t_pt=5502
Basically, you either have to care enough to set your own pinion angle with tapered blocks, shims, or by relocating the spring pads, or you don't care and you use flat blocks. I used flat ones, went back to factory after my pinion seal started leaking. It's needless wear thats easily correctable, but it's your money.
I assume Ford hasn't changed the tapered blocks out with the new u-bolt configuration, but I don't have a 2011... so I can't be sure anyways. Your 2" factory blocks should be tapered, so that's how you'll know. I don't think any aftermarket companies would bother making two parts dependant on wheel base of one brand, seeing as how many of them market 2" blocks as being "stackable" anyways.
Leaf Spring Axle Shim
owenstout
05-12-2015 06:02 PM
