Getting sick of my squeaky fan belt when I got the truck fan belt was old and crapy put a new one on first day it jumped over shredded half of it tensioner bearing was gone replaced the bearing put another new belt on watched it jumped over again but caught it in time all bearing are good other than the power steering pump slides over but I here that's normal what else could it be?
You might check the hub on the water pump. I had one that started to come off the shaft, and the belt would ride to the inside, and wore a couple of ribs off the belt.
^^^^^ Just eye-balling the pulleys from either side (fender) of the engine might identify a pulley that's out of alignment, either one that's too far forward / too far aft, or one that's not in the same "plane" (at a bad angle) as the other pulleys.
In particular, wind up the tensioner and unwind it again, and watch the pulley as you do so. Even if the spring is tight, if there's wear in the body of the tensioner, you'll notice that the angle of the pulley changes as the spring unwinds and it tensions the belt. That can chew up a belt.
