starter? battery? alt?
Old 10-05-2011, 05:14 PM
cobra3371's Avatar
cobra3371
cobra3371 is offline
I have a 96 f150 and if I drive a short distance and shut The truck off it dosent have enough juice to turn the truck over. But if I go to town and back it will fire up no problem. Im kinda thinkin its starter draw...anyone run into this problem
Old 10-05-2011, 05:19 PM
NFLEagles1's Avatar
NFLEagles1
NFLEagles1 is offline
Hmm, well if you start with the basics, I would attach voltage meter. With truck off, measure voltage, then with truck running, measure again. While stopped the battery should be close to 12V I believe and while running, it should be around 14v? That would be the alternator.
Old 10-05-2011, 05:26 PM
cobra3371's Avatar
cobra3371
There's a batt meter in the truck and its usuly around the same..but as soon as I turn it over it drains quick...even on a good start..but will still check with the voltage meter
Old 10-05-2011, 05:38 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Before you go too far throwing parts at it, you might want to go by a parts store and have them LOAD test the battery..
Old 10-06-2011, 11:38 AM
cobra3371's Avatar
cobra3371
Thanks for the help guys..after the truck wouldn't start when I was in the woods fishing (a fellow fishermen came along and gave me a boost) I went stright to the garage and got a load test done and sure enough the batt was the problem...new batt and good to go
Tileman5
11-09-2011 02:23 AM
tm0231009
23
01-13-2011 02:43 AM
kroach2002
06-27-2009 05:19 PM
gmills
12-15-2008 07:50 AM
RedInline6
01-27-2004 11:53 AM
Quick Reply: starter? battery? alt?
