Gas Tank vent or vented cap?
A new (in the box) plastic gas tank was with my 54 F100 when I bought it. It is from a company called Tanks. It fit fine in the original location. I plumbed it with steel NAPA brake lines to the 223 six.. The new sending unit came with good directions and went in with out any problem. There is a tapping for a vent. Should I plug it or use it? If I use it, where should it be run to? What kind of fitting should be at the end of the line?
Thanks
Bob
Thanks
Bob
My thinking is that if the original tank did not need a vent, you don't need one either.
The vent might be necessary for fuel injection with supply and return lines that could cause the tank to see a little pressure build up. Or for later model evaporative emission applications where vapors are returned to the tank.
Thanks
Bob
Thanks
Bob
Hi Guys,
I went round & round with the guys helping me with this build.
Their argument was that they had been racing dirt track for 20 years & they don't require rollover valves so why put one on this big 'ol truck.
My argument back was my garage faces west it's hot as he-- in there & I have a water heater with a lit pilot light in a closet in the garage. I don't want to take any chances...
The valve is only $10 - why not put one in?
Ben in Austin
Ben in Austin
These old trucks had a filler pipe that was big, unobstructed, and almost 2 inches in diameter. Modern filler pipes have a small hole, just big enough for the pump nozzle to fit so these need an air by pass. The old big filler pipe needs no bypass since there is plenty of room to let the air from the tank vent out. All the tractors and machinery on our farm had similar, big filler pipes and unvented caps. I would presume that venting would not be necessary if a large stock type filler pipe is used. This is only my opinion though.
Next time I'm at the auto parts store I have to pick up a vented cap. I have a non vented cap on it now and it built up a lot of pressure, which I didn't realize until I was working on something under the hood and took one of my fuel lines off... squirted gas all over. Scratched my head, and then took the gas cap off and heard the pressure release.... Original tank.
the mustang cap I used temporarily for the green tank and mustang tank and filler neck, had a little groove in the sealing edge.. that was the vent.. both in and out.
these were all stock parts.
I replaced the filler neck with a tube & cap from a late model silverado (short, straight, screw in cap.) it is NOT vented... so I had to add something else..
this is NOT about speed to fill the tank, this is about the tank sitting with fuel and the vapors escaping. On the later model vehicles this goes thru a charcoal canister to capture the released material.
Sam
I'm not discouraging the use of the rollover vent. Safety is a good thing. But to be clear, that valve will do nothing for sealing fumes from your hot garage and away from your gas water heater. The valve only closes if it's tipped upside down. Otherwise, it's a normal, open vent.
