Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009+ F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2009+ F150 Discuss the 2009, 2010 and new 2011 Ford F150 SPONSORED BY:
  #1 (permalink)
Old 09-30-2011, 05:54 AM
MKEBoost MKEBoost is offline
Garage is empty, add now
MKEBoost is gaining momentum as a positive member of FTE.
3.55 Rear Axle?
So I've seen a few posts about rear axles and ratio's etc but I don't see too much mention of the 3.55 ratio with the EcoBoost motor in the F150 4by. Yet when I configure a F150 SCrew 4by with Eco, it automatically defaults/adds the option for 3.55 LS ratio. Also, most if not all F150's I've seen on the lots around here with the Eco have the same 3.55. Is there something I'm missing here...why are most people posting that they have something different? I hope the 3.55 will be good, 'cause my truck is on the way from the factory with it in it.
  #2 (permalink)
Old 09-30-2011, 06:25 AM
shortride's Avatar
shortride shortride is offline
2010 Ford F-150
shortride is gaining momentum as a positive member of FTE.
A lot of folks are special ordering their new F-150's with 3.73:1 gear ratio. It will improve towing and help for those that put larger tires on their trucks. The 3.55:1 setup is an average mid-range ratio good for highway driving and is probably considered standard equipment on a lot of models. Don't expect to get the best fuel mileage with a 3.73:1 but if you look at a lot of picture of some of these truck you would think there isn't much consideration except trying to make the truck look good.
  #3 (permalink)
Old 09-30-2011, 06:54 AM
Ralph Ralph is offline
Ralph is starting off with a positive reputation.
I'm trying to figure out the same thing! I want to order a new 2012 in the next few days and trying to figure out which axle is the best choice. I thought standard was 3.31 and a optional 3.55 or 3.73 was available?
  #4 (permalink)
Old 09-30-2011, 07:17 AM
shortride's Avatar
2010 Ford F-150
Quote:
On page 42 and 43 of the 2011 F150 brochure it lists all of the models available and which axle ratio is available. The axle ratio's go from 3.15 to 4.10.
These are the axle ratio's listed under, CONVENTIONAL TOWING - MAXIMUM LOADED TRAILER WEIGHT RATINGS (LBS)
3.5 Ecoboost
3.15
3.31
3.55
3.73
4.10
3.7 V6
3.55
3.73
5.0 V8
3.31
3.55
3.73
6.2 V8
3.73
4.10
I'm not sure if this means these are the only axle ratio's available for the respective engine or not.
  #5 (permalink)
Old 09-30-2011, 08:14 AM
Augster's Avatar
Augster Augster is offline
2009 Ford F-150
My Garage
Augster is gaining momentum as a positive member of FTE.
IMO, unless you will be towing >5,000 lbs much of the time or for long distances occasionally, the 3.55's will be just fine, even with 33's.
You have to keep in mind that the 6-speed has some very low gears (1: 4.17, 2: 2.34, 3: 1.52, 4: 1.14, 5: 0.87, 6: 0.69) and you have the ability to lock out O/D so you should be able to keep the engine at or near peak torque for most of your driving needs.
__________________
2009 Platinum 4x4, Black on Sienna Brown, Moonroof, NAV, TBC, Extender, Man-step:
Line-X, HBS, ReadyLift, Recon, T-Rex, Gitanos, Nittos, BAKs, Eagle Eyes
  #6 (permalink)
Old 09-30-2011, 12:00 PM
ThirdsACharm's Avatar
ThirdsACharm ThirdsACharm is offline
2011 Ford F-150
ThirdsACharm is starting off with a positive reputation.
I mentioned this the other day in another thread, and have to echo Augster's thoughts - unless you're towing heavy, 3.73s with the Eco is overkill in my opinion. I went with 3.73s and would have been fine with 3.55s.
__________________
2011 F-150 FX4 EcoBoost, Crew cab, 6.5 bed, Ebony Black
  #7 (permalink)
Old 09-30-2011, 01:05 PM
simprog1700 simprog1700 is offline
simprog1700 is starting off with a positive reputation.
I have a 3.55 in mine and am more than pleased with it.
  #8 (permalink)
Old 09-30-2011, 03:12 PM
Skoiv's Avatar
Skoiv Skoiv is offline
Skoiv is gaining momentum as a positive member of FTE.
I tow an 8000 lb trailer with 3.55's and absolutely love it. No regrets here.
__________________
*11 F150 XLT SC, long bed, ECOBOOST chrome and tow. Ingot Silver. 3.55 gears. 4x4
*1980 F250 4x4, 351M, Edlebrock intake, cam, lifters and carb. 3" single exhaust with 40 series Flowmaster. 3" Tough Ctry lift, 33" BFG A/T's, 3.73's, Dana 60ff Powerlock rear. Converted 2x4. Camper Special
*11 Taurus Limited
*06 E350 Cargo Van
  #9 (permalink)
Old 09-30-2011, 03:38 PM
Truckpilot1329 Truckpilot1329 is offline
Truckpilot1329 is starting off with a positive reputation.
If you're driving down the road in your truck equipped with 3.31 gears, going, say about 65 and let's say that tach is reading 1600 rpm.
If you were driving with 3.55 gears, you'd be taching 1700 rpm.
With 3.73 gears you'd be taching 1800 rpm. It's a linear function.
4.10 gears would put you at 2000 rpm. Now we're taking some additional fuel burn.
It would be nice to test drive various geared vehicles and see what the difference is, but most of us don't have access to a bunch of test trucks.
My experience is that getting high speed gears, like 3.31s for better milage in a mountain environment can backfire, as the vehicle has to downshift sooner going uphill, whereas it might make the grade in a higher gear. The fuel burn on a downshift is very pronounced. The engine has to make the same HP to get up the grade at a constant vehicle speed, but is more fuel efficient at the lowest engine rpm.
Another point of interest is that some F-150 4x4 models with the 18 inches wheels which means 275x65x18 tires.
The optional 20 inches wheels come with tires that are 275x55x20.
What interesting is that both these tires sizes are virtually identical in diameter; 32 inches, for whatever that is worth.
  #10 (permalink)
Old 09-30-2011, 05:24 PM
tseekins's Avatar
tseekins tseekins is offline
2011 Ford F-150
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
[quote=Truckpilot1329;10869997]If you're driving down the road in your truck equipped with 3.31 gears, going, say about 65 and let's say that tach is reading 1600 rpm.
What interesting is that both these tires sizes are virtually identical in diameter; 32 inches, for whatever that is worth.[/QUOTE]
That's worth a lot as there are tons of tire related questions on here. Many folks don't realize that little tidbit about factory 18's and 20's.
For the ecoboost engine, I would consider the 3.55 axles to be optimal unless one is towing 11k every day.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
  #11 (permalink)
Old 09-30-2011, 07:57 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is starting off with a positive reputation.
My boss's King Ranch ECO has 3.55's, and that truck has plenty of power. 373's are probably better left for towing and hauling.
__________________
2013 Keystone Outback 33' Travel Trailer
2013 F-150 Max Tow Ecoboost Lariat
2011 Ford Fusion Sport
  #12 (permalink)
Old 10-01-2011, 03:58 AM
Wow..great information from everyone-thanks. My truck was ordered with the 18" factory wheels and as mentioned, the 3.55 limited slip rear which sounds like it will be fine. I'm not planning on changing tire size or towing large loads (or any load for that matter).
  #13 (permalink)
Old 10-01-2011, 05:29 AM
tseekins's Avatar
2011 Ford F-150
Quote:
But the good thing about the ecoboost engine with any gear set is that you can tow. I believe the 3.15 axle gets you a 7500 lb tow rating. That speaks volumes for the engine / transmission duo.
With the 3.55, you'll be more than well equipped to handle most any task that an F-150 is rated for.
__________________
Tim
2010 Ford Focus
FTE Guidelines
  #14 (permalink)
Old 10-01-2011, 06:04 AM
shortride's Avatar
2010 Ford F-150
I wonder what kind of fuel mileage one could get with an EB and 3.15:1 setup.
  #15 (permalink)
Old 10-01-2011, 08:36 AM
LCPullman LCPullman is offline
2011 Ford F-150
LCPullman is starting off with a positive reputation.
I have the ecoboost with the 3.55 axle. It tows 6000lbs very well, and when its empty I can still get about 23mpg on the highway.
Tags
2011, 355, 87, axle, bearing, change, diesel, differential, ecoboost, explorer, f150, ford, gear, lock, rear, regular, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
