I think I found the problem...
#46
That's what the computer called for. Time to give the manager an ear full?
maybe the worst part about Autozone giving me this is, my auto shop teacher last year had an account with them because they were "better than most". I cant imagine what the others are like.
#47
I avoid the chain parts stores when at all possible, i'm fortunate enough to live in a small town where we still have an independent parts house, the owner works the counter himself, he's there Mon-Fri, 8-6, he knows my name, he knows my trucks......it's not some random kid asking me "2wd or 4wd" when all i want is spark plugs.
#48
I avoid the chain parts stores when at all possible, i'm fortunate enough to live in a small town where we still have an independant parts house, the owner works the counter himself, he's there Mon-Fri, 8-6, he knows my name, he knows my trucks......it's not some random kid asking me "2wd or 4wd" when all i want is spark plugs.
I just hope it didnt do any damage.
#49
#50
Ok, thats good.
As for the initial problem, on the short test drive it did seem to do much better. Thanks for all y'alls help
#51
#52
Ok, went and got the new distributor. They said they'd give me a 10% discount next time I come in. Not much but better than nothing. Put the new one in, had to rotate the engine with a socket on the crankshaft. Engine started, oil pressure gauge stays over the A&L, also showing superb vacuum(22-23 in park). The "empty spray can" lifter sound is still there after a few minutes at idle. How long should it take to get them full of oil again?
#55
#56
Ah ****! I noticed earlier that my EGR was unhooked so I reconnected it. SYMPTOMS RETURNED Unplugged it and it ran perfect again.
Looking at a few possibilities:
1. I installed the wrong orifice washer when I installed the ERG.
2. The timing is set to around 8-10* BTDC. Maybe it would do better with the called-for 6* BTDC?
#58
I had this very same issue with my inline six in my 83. While it isn't a "fix", since I was pulling the old engine shortly I made a restrictor plate for my EGR so that it wouldn't overload the engine with EGR gases on decel.
It worked great fwiw, but I'd rather see you get it fixed properly than rigging up a get-by. Hope ya have good luck with it!
#59
Looky here:
In case you cant tell, the valve is saturated with some liquid. Too thin to be oil, but smells like it. Not gas cause it wont burn.
I filled up yesterday and calculated 7.1mpg. While it was better than the 6.4 I measured after the previous fillup, its way down from the 8-8.5 I was getting this summer.
