70's roll bar upgrade
#31
A few. Next after the bar is some line x. I'm still going to repaint the drilled holes.
Time to get back to work on it in the morning. Will post some pics.
#32
Ok all today I welded up two stands to mount my hi lift on. They are made from a 1/2" grade 8 bolt welded into a 1 1/2" X .25 wall tubing.
Once I get it all painted it will be held down with nylocks.
Next I bent and welded up two loops for a safety strap around the tire out of 3/8" rod.
Strap cut to length.
This is where it sits for now. I should get some more done Friday or saturday. Time to make a Jerry can mount.
#35
By set up if you mean welder. My tig welder is a Hobart tigmate and my plasma is a Hobart airforce 625.
#36
#37
Ok all. I got some more work done on her today. Added some extra tie downs on the bottom front legs for a motorcycle or two.
I also finished the Jerry can mount. It's dead simple. You just set the can on the angle iron and there will be a ratchet strap over the top hooked into the bottom under the can.
I know the second pic is kinda dark.
Last I cut out the backing plates that will go under the bed.
This Thursday I will sand blast the whole thing and prime it. Hopefully Friday I can lay on some paint. That is as long as the rain holds off.
#39
Thank you. I honestly wouldn't even use a roll bar if I couldn't get it to perform other functions too. A roll bar wouldn't originally even been on my radar if the spare, when it was under my truck didn't look like it would hang up on a speed bump.
#41
Tig weld if its paper thin or if it's an art project. I know I said this before Chase. I dont do anything half *** but I couldn't be bothered with spider web gussets and cute little tig beads unless necessary .
#42
#43
#44
