2004 Ford Ranger 2.3L Surging
Old 09-24-2011, 05:19 PM
2valvekid's Avatar
2valvekid
2valvekid is offline
I have a 2004 Ford Ranger 2.3L 5 speed with 135,000 miles that is having the surging problem. It does it worst around 2000 RPM's, but does do it across the entire power band. I have replaced plugs, Wires and cleaned the MAF. At this time it is not throwing any codes.
Any help would be greatly appreciated. Thanks
Old 09-25-2011, 05:10 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
-try and catch a pending code
-change fuel filter/fuel pressure
-vacuum leaks
-check/change air filter and intake
Old 09-25-2011, 08:06 AM
pawpaw's Avatar
pawpaw
pawpaw is online now
The IAC is responsible for engine idle speed, so maybe consider removing & cleaning it with a plastic safe spray & see how it goes.
Cleaning may not last, it didn't for me, but was a good trouble shooting step. It can act out & not set any trouble codes.
Put the PCV valve & it's plumbing on your suspect list too, as it's time for replacement & I believe Ford does it for free on your engine. Maybe the vapor recovery system also if you don't have joy cleaning the IAC.
More thoughts for consideration. Let us know how it goes.
dorado
10-19-2011 01:58 PM
davalann
10-10-2011 07:49 PM
rHammer
09-25-2011 07:55 AM
monkeykoder
11-21-2009 11:02 AM
Tremor23
09-03-2007 11:15 AM
Quick Reply: 2004 Ford Ranger 2.3L Surging
