Pilot bearing for 52 three speed
Old 09-23-2011, 06:15 PM
Scummer52's Avatar
Scummer52
Scummer52 is offline
Replacing the clutch on my 52 three speed transmission. My flywheel has a bushing, not a pilot bearing. New clutch kit includes pilot bearing. Should I press out the bushing & replace with the pilot bearing, or leave it as is. Truck has been running with combo (bushing trans spline/shaft).
Thanks!
Old 09-23-2011, 06:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Some folks like the bushing because even when wallered out, they don't seize up. Nevertheless, I went with the bearing, because it has less drag when the clutch is pushed in and doesn't allow any wobble.
If you look at the bearing, I'd about guarantee it's made in China. Just make sure it has grease in it before you install it.
Old 09-23-2011, 06:47 PM
Scummer52's Avatar
Scummer52
Thanks for the info. This is my first rebuild of a "pre-1970" truck, so i'm learning alot. First I've ever seen with a bushing. Planning to drop the Engine & trans in tomorrow! Thanks again.
swade-o
1999 to 2016 Super Duty
11-17-2015 11:24 AM
jiveturkey692000
03-05-2011 09:53 PM
DrCharles
Engine Swaps
01-06-2010 08:48 AM
weswes01
10-15-2007 10:28 PM
wick246
23
09-01-2006 02:01 AM
Quick Reply: Pilot bearing for 52 three speed
