Engine question
09-22-2011, 03:15 PM
on
Engine question
Okay guys...I need to get a new alternator for my truck (see other post). I just bought the truck and don't know what motor is in it. How can I determine which motor I have in my truck? Keep in mind this is a question coming from a non-gear head, I've always worked on diesels and don't know much of anything about gasoline engines.
09-22-2011, 03:22 PM
09-22-2011, 03:23 PM
WOW! lol Well read the data plate by the radiator or post your VIN up and well tell you what you have.
09-22-2011, 03:34 PM
Or take a picture of the top of your motor!
09-22-2011, 03:42 PM
on
Quote:
Originally Posted by
Edgethis
Take is easy on me fellas....I skipped all my shop classes in high school...
VIN:
1FTEX15N2TKA31237</pre>
09-22-2011, 03:43 PM
Your VIN number:
1FTEX15N2TKA31237
Manufacturer: Ford Motor Company, USA
Make: Ford
F-Series - F150 4x2
Body Type: Supercab
Engine: 5.0(302cid)
Cylinders: V-8
Fuel Type: Gasoline
Horse Power: 185
Model Year: 1996
09-22-2011, 03:46 PM
majorpecs1
lol I'm sorry, its just one of those questions that catches you off guard, like "Is my truck 4wd or 2wd"
on
09-22-2011, 03:49 PM
Way easy to change. Two bolts and an electrical plug. Took me all of 10 minutes.
09-22-2011, 05:32 PM
Now would be a great time to upgrade from the 95 amp to a 130 amp from a PSD of the same year.
The stock alternator is just barely adequate in my opinion.
09-22-2011, 05:33 PM
Its a plug and play swap for the diesel one.
09-22-2011, 05:35 PM
TheWhiteBeast
Don't forget to disconnect the battery and remove the belt.
09-22-2011, 05:40 PM
TexasGuy001
nah, belt comes off by itself when you pop those bolts out.
EDIT: IM KIDDING DON'T TRY THIS. SERIOUSLY
09-22-2011, 06:46 PM
on
Ok do I took the belt off and the alternator pulley spins fine...the crankshaft isn't spinning and neither is th e tensioner
09-22-2011, 06:51 PM
You won't be able to turn crank by hand unless your names Bruce banner. the tensioner however should turn pretty freely...
