Fuel Pumps
I used Airtex because I could get it that day. I have found that the sender does not read fuel level accurate until I get below half a tank of fuel.
I got what I paid for, cheap prices = cheap parts.
When the time comes to have to replace them again, I will go back with motorcraft even with the higher prices.
I just had to replace mine a couple weeks ago. I bought the motocraft one from rockauto because the last one I put in (whatever was in stock at carquest) did not last very long. It did not come with a sending unit, but I used the OEM one that came with the truck.
If you plan on keeping the truck several years, get a motorcraft.
Oh... and you wont have to spice the wires together inside the tank. having those wires spliced together in the middle and bouncing around in there makes me nervous.
Amazon Delphi Pumps
Recently replaced both fuel pumps on my 1996 F350 XLT with the pumps listed below. At less than $100 each I thought I'd roll the dice and try non-Motocraft at 1/4th the cost. Parts look good and fit well, I'll let you know if I run into any problems.
Good luck
JJ
FG0198 - Mid Tank
Amazon.com: Delphi FG0198 Electric Fuel Pump: Automotive
FG0199 - Rear Tank
Amazon.com: Delphi FG0199 Electric Fuel Pump: Automotive
Good luck
JJ
FG0198 - Mid Tank
FG0199 - Rear Tank
FilmGuy
15
05-31-2014 07:22 PM
RustyTrustyF150
10-07-2007 06:28 PM
