Best spark plugs for our engines?
09-14-2011, 10:20 PM
on
Just curious what everyone else has tried and what has worked well. I know you can't go wrong with motorcraft replacements, but would like to hear what others have done. Out of everything I have read, copper plugs seem to work the best. If you guys don't mind, plug type/part number and gap would be great. I am interested in what gives good mpg and throttle response.
09-14-2011, 10:50 PM
Autolite Coppers...Gapped @ .044"......Other than Motorcrafts at the same gap...
Hands down...
09-14-2011, 11:01 PM
on
Wow, got a response a lot quicker than I expected to, thank you. What made you decide on the autolites?
09-14-2011, 11:07 PM
on
Quote:
Originally Posted by
SideWinder4.9l
Hands down...
yep.....
Autolite was OE before Motorcraft
09-14-2011, 11:09 PM
Cheap....Gets the job done......And fit in with the thermal/burn range......
Each metal allows a different temp* spark....Platinums are a hotter plug than coppers...Obviously....
Motorcraft/Autolite's have given me the best perf/usage per $.....
Just my $.02....
(Btw, check the moniker under my name.....FTE Batman.....I'm ALWAYS on....Only gone for a lil while at a time...)
09-15-2011, 10:41 AM
On my 1986 [carburated], I use Motorcraft SP435 [copper], which is specified on 1987 and later [fuel injected] gapped @ .052" since I did the Duraspark conversion.
09-15-2011, 11:12 AM
09-15-2011, 11:20 AM
on
Thanks for all the responses guys! I might try some Autolites on my next plug swap.
09-15-2011, 02:05 PM
big-ugly
Good...Just be sure to gap them before they go in...
Sometimes, if the box has been dropped, etc...The electrode gets mashed together.......And will cause issue...
A 3 second gap/inspection will save 30 of headaches...
09-15-2011, 04:26 PM
autolite, i wouldn't think i was buying crap if i went with motorcraft though
09-15-2011, 07:05 PM
on
09-15-2011, 07:08 PM
NGK...if you want to feel exotic.
09-15-2011, 08:03 PM
on
Harte3
I don't think NGK would do good in fords Big cubed engines, And definitely not the 300?
09-15-2011, 09:49 PM
on
I personally hate NGk's, and will not run them in anything I own. They are like a fram oil filter to me.
09-15-2011, 10:44 PM
on
big-ugly
Fram and Autolite are made by same company,
