460 dual exhaust headers
Old 09-13-2011, 08:46 PM
ryanscott's Avatar
ryanscott
ryanscott is offline
I have a 1996 ford F250 4x4 460 7.5L xl single cab. I bought it with a exhaust leak where the exhaust meets the manifold. I have takin it around town and it is a pain to fix due to the fact that the bolts are rusted out and are impossible to replace. So me and my dad are going to take off the manifolds and cut the exaust and put headers on it and then have the pipes re ran to the mufflers by a shop. Now here's the question: What are the best headers. I am on a tight budget and want to order through summit racing. But which of these three are better for true dual exhaust without using the y-pipe?
1) Hedman Hedders 89510 - Hedman Street Hedders - Overview - SummitRacing.com
2) Hedman Hedders 89460 - Hedman Street Hedders - Overview - SummitRacing.com
3) Hedman Hedders 89511 - Hedman Street Hedders - Overview - SummitRacing.com
Old 09-13-2011, 10:01 PM
Edgethis's Avatar
Edgethis
Edgethis is offline
How do you plan on running true duals? Its a mess on a 4wd.
2 out of the 3 you listed include a Y-pipe. If you are running true duals, why bother with paying for a y-pipe?
I'd go Long tubes, not shorty or mid length.
Old 09-13-2011, 10:03 PM
Nevada Al's Avatar
Nevada Al
Nevada Al is offline
On a budget or otherwise I would run with a single mandrel bent 3" going through a quality straight through muffler like a Magnaflow.... For this the 89510s with the y pipe will serve you well... and sound will be amazing.. Do yourself a favor and strip them down and and sand them clean then apply VHT paint to them be sure to bake the header according to directions and the finish will last forever..
Its a pain to run duals on these trucks...not to mention all your really gaining is an extra 40 or so lbs of metal under your truck and twice the price..
Even Banks systems run a single pipe....
EDIT to add.... ditch the cat, hollow it out (legallities), or replace it with a high flow...
Old 09-13-2011, 10:20 PM
ryanscott's Avatar
ryanscott
im not running any cats right now, its manifold to pipes to mufflers out the back. It is already set up for true duals and i just want to put the headers on. Im more wondering if they are tuned a different way for the y pipe and the duals.
Old 09-13-2011, 10:36 PM
fdude64's Avatar
fdude64
fdude64 is offline
if you have a zf 5 speed with an external slave cylinder you may run into pipe clearance problems
Old 09-13-2011, 10:57 PM
Nevada Al's Avatar
Nevada Al
Well if you have the pipes already any shop can connect them to headers the 89510s would work without the y pipe the collectors hang down plent far...
That being said, most shops won't touch a vehicle exhaust like you describe with no converters.... Something about thousands of dollars in fines .... Unless you know them well, your gonna have to go the private route....
Old 09-14-2011, 06:49 AM
ryanscott's Avatar
ryanscott
I have a automatic transmission on it. When i take it to a shop i will have them set it up to where it isnt bad. I have already visited plenty of shops and they havent said anything about the way its set up just stuff about the crappy job the previous person do.
Old 05-06-2013, 11:42 PM
eagle275's Avatar
eagle275
eagle275 is offline
I know this is an old thread, but any update? Looking at these same headers.
Old 05-07-2013, 07:20 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
The 1st and 3rd summit link are the same header, first is a painted and third is ceramic coated.
It's up to you which one you get.
Then just save yourself time and money, and buy a 4" diesel exhaust for the truck, with muffler. Use a cat, don't use a cat, I don't care. I've done it both ways and seen zero power loss (with a good stock 20+ year old cat)
Single 3" is fine on a stock 460, but 4" won't hurt.
Old 05-07-2013, 05:19 PM
BigBlockF350's Avatar
BigBlockF350
BigBlockF350 is offline
I've got these old Hedman long tubes in my truck (in sig): http://www.summitracing.com/parts/he...rd/model/f-350
It's a cheapo pair, but they've been there for 15 years and they're holding up fine.
I've got true dual 2.25" (or 2.5", don't remember...) pipes and Flowmaster 50s, and I can take pics for you of the whole system if you want. Should look similar to the setup you're doing.
Old 06-29-2013, 04:58 PM
smokin tires's Avatar
smokin tires
smokin tires is offline
I have im guessin a 4 in mbrp diesel exhaust for a 7.3 powerstroke. I was wondering if it would work on my 460.
Will backpressure be a problem?
How about sound?
Old 06-29-2013, 05:35 PM
42x's Avatar
42x
42x is offline
Since this is an old thread... I found when looking for headers is to look at the reveiw of previous buyers. Have them gone easy the first time is worth it's weight in gold. Having to take them on and off a couple of time to tweek them to fit is a pain. Short vs Long tube headers, unless you are at max RPM there is really no difference (maybe 3% or less change) in horse power between the two. Shorties are eazier to install with exsisting systems.
Old 06-29-2013, 06:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Depending where you are those headman header will make it ONE season then they will be rotted out and you will be replacing them.
I bought L&L triple nickel plated headers for one truck(in 1998) and they look like the day I put them on, other than a lil blueing
On another truck I put on Banks Torque tubes and their Y-pipe. All stainless and it still looks new(installed in 01)
Old 06-29-2013, 07:13 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I also have experience with the L&L headers (and a 4" diesel exhaust with twin bullet cats) and the 100% banks kit. Both are fantastic headers. Banks comes with a great y-pipe, its all stainless, and all you need to do is reuse factory cat (which I did on this truck) and get swaybar bracket from banks (F350 w/manual) The L&L headers I made my own 3" stainless exhaust from each header into their own bullet cat that went into a dual 3" inlet single 4" outlet stainless magnaflow muffler, then into a 4" aluminized diesel exhaust.
Both setups were 4-5 years old in Maine salty winters and lakeside summers, looked fantastic when I sold the trucks.
Old 06-29-2013, 07:28 PM
smokin tires
How did it sound?
Quick Reply: 460 dual exhaust headers
