zf 5 speed problems!
hey just bought a 1995 ford f250 7.3l directinjection turbo diesel. On the way to work today the trans started to smoke and make a grinding sound.
the clutch is new, (so the previous owner claims).
i drove a whopping 33.7 miles with the truck before the trans died.
truck info
1995 f250 7.3l direct injection turbo diesel
ZF 5 speed 4x4
337264.7 miles
truck info
ZF 5 speed 4x4
337264.7 miles
Yeah, more detail. Does it grind in neutral or clutch down, or only when propelling the truck? What color smoke? From what part of the tranny? Did you check the fluid? Did you check for obvious stuff like some foreign object wrapped around a driveshaft?
BTW, 4x4 or 2WD?
How does the clutch pedal feel? What about the shifting, engine off and engine on?
BTW, 4x4 or 2WD?
hey i have been busy with work,
the trans would make the noise whenever the truck was running. i pulled the dust cover off of the fly wheel and clutch and ball bearings and springs came out. im geussing that it is the throw out bearing and the clutch return spring.
i talked to ford and for the repair they said i would need a new clutch kit and a new fly wheel. it has the dual mass system on it and the best price for a fly wheel that i have found is $750!
Any cheaper options for this repair?
when i put a clutch in my 6.9l the t-19 clutch was only 150.
I got a clutch kit (including pressure plate and bearings) and solid mass flywheel from Valair for $700.XX shipped to my door. That was for the 350 hp one. There are cheaper alternatives offered by Valair, also.
Here is where I found my clutch kit and flywheel.
There is no "return spring" inside a clutch. The fingers of the pressure plate push the fork (and thus the hydraulics and the pedal) back and engage the clutch; there is also a "helper" return spring on the pedal arm. The springs are more likely bits of the dumb-mass .... er.... dual-mass flywheel coming undone. Flywheel is up way past its bedtime.
[quote=6.9lXLTf250;10831153] i pulled the dust cover off of the fly wheel and clutch and ball bearings and springs came out. im geussing that it is the throw out bearing and the clutch return spring.
If any of the parts looked like the ones in the fallowing link I would be very suspicious of the dmf. When mine went bad the symptoms were engine shaking and vibration, (I thought it was a engine miss).
https://www.ford-trucks.com/forums/1...came-from.html
hillbillyk
04-29-2011 10:55 PM
cgrant
03-16-2009 12:16 AM
turbozeke418
11-12-2006 02:43 PM
