1987 F250 ignition problems
1987 F250. 7.5L gas, 460 BB, carbureted. Duraspark ignition.
A couple of problems. First one is I bought an Accel coil (8140c) and mounted it where the stock one is right on top of the driver side front corner where a lot of heat is generated. When it gets hot it shuts off and will not start again until it cools down. If I mounted it on the firewall would it eliminate this problem?
Second one is how do I check and adjust the pick up coil?
Thank you in advance.
There is no adjustment for the PIP aka stator in the distributor.
Use this to check it: SBFTech.com TFI Module/Hall Sensor Testing Procedure
I do have the DS system and when the vehicle gets hot it shuts off. I replace the coil with my stock one and it starts immediately. I have read somewhere where the coil gets hot then shuts off ignition.
Question relating, I have an ignition suppression resistor or ballast resistor on this vehicle and it is supposed to reduce/limit the voltage going to the positive side of the coil. I cannot find an ignition suppression resistor/ballast resistor anywhere
I think that is a noise suppressor for the radio, I could be wrong but I doubt it, anyway Ford sells them but has to be ordered most likely...your truck have a EEC? I don't think the new coil is in play here, if wired correctly...Motor starts, dies when hot, look to the PIP/module circuit
No EEC on these trucks.
You're right Slipfordman, that condensor is for radio suppression.
On my truck the resistor wire is in the cab, not in the engine harness.
But it should be easy enough to probe the coil feed with the ignition in 'run', looking for 7-8V.
When you hit 12V you are between the switch and the resistor.
