1.9 turbo problems
1.9 turbo problems
I have a 1.9 motor and i put a turbo on it. the motor has diamond pistons and crowder rod its all build to hold over 20 lb of boost it has a MSD boxs, crank trigger, innercooler and a FAST computer. the motors has been tuned on a dyno and has been running great until now
the problem
when reving up the motor when it hits 5000 RPMS it drops the RPMS back down to about 3000 even when floored.. I replaced the crank trigger sencer and the TPS what esle could it be ??
the problem
which MSD box are you using? the sport compact? if its the one with selectable cylinder (4,6,8) check your switch. if your using more than one box thats no bueno... if it has anything to do with the MSD its usually the CPS thats playing with it.. have you tried the troubleshooter for the MSD?
joeflexromine
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
03-07-2012 05:39 PM
parkland
10-28-2008 08:15 PM
birdmanslopy
1983 - 2012 Ranger & B-Series
02-17-2007 11:52 PM
