87 F250 7.5L won't run over 50 mph.
Just bought an 87 F250 7.5L truck and it starts easily, idles smoothly, and drives nicely... until you reach 50-55 mph. When it reaches that speed, it dies.
It has dual tanks. When the selector is in the front position there is an electrical buzzing sound. When it switches to the rear tank it goes away.
I recently tried driving the truck on the freeway with the front pump on. As usual when I hit 50 it fluttered and sputtered and died. I shifted to neutral for a few seconds and with some pumping of the pedal, got it started again. Drove again up to 50 and it died. Repeat until home. When I switched it to the rear tank it didn't make a difference.
Other symptom is that the amp meter in my instrument panel goes between the last red line and above the first over charge red line. I am not sure what is causing this.
I need it to drive to Alaska in 5 days. 2300 miles. Don't want to drive that at 45 so THANK YOU for any assistance!
What I have done:
Autozone tested the battery and said it was fine.
Change the oil and used an engine grime cleaner.
Prayed a lot.
Cried a little.
What I have done:
Prayed a lot.
Cried a little.
A couple pictures
In this picture you can see that the brown spring to the left of the blue thing isn't where it should be. I fixed that. Not sure what it is for...
https://picasaweb.google.com/lh/phot...eat=directlink
In this picture you can see that the bottom is wet. It is wet with gasoline. What does that mean.
Here is the whole thing. What part is the fuel filter? I have yet to get a repair manual for this truck and am relying on what I know about vehicles already.
http://picasaweb.google.com/lh/photo...eat=directlink
