Can you ID an axle from this tag?
Probably too late, but this shows where to find id info. If you've id'd it as 60, the tag looks like the ratio tag showing 4.10 ratio, it measure out, what else is there to know other than if it's a howler or a bolt-in runner.
http://www.nationwideparts.com/differentials.htm
Good luck with it.
Good luck with it.
that tag says its a dana 60 off a 94 f350 front axle heres a link to dana library
http://www2.dana.com/expertforms/depdf.aspx?prod=AXL
Differential identification charts
Good luck with it.
Good luck with it.
My Tag also says this V131C 10 10 2 7B26 That's all the numbers there was nothing else .
kyle j
12-05-2016 10:01 AM
sharker98
13
12-20-2003 08:57 AM
