Timing position is way off !!! 5.0L
I have been experiencing pinging under acceleration and in between gear shifts. Pull out the timing light, and the timing mark on the balancer is about 180* from where it should be. It shows up at about the 4-5 o'clock position. The timing tab is at about the 10-11 o'clock position. What gives?
A couple of possibilities:
1. The outer ring on the damper has slipped, and is now sitting where it shouldn't. See if the rubber between the outer ring and inner hub is all torn up. If so, it's broken, and you will have to replace it.
2. Your distributor, or the wires on the rotor, are not installed correctly.
I'm going with the balancer rumber deteriated (I also had no idea you need to unplug the tfi to set timing???) Thanks
josiewales
10-28-2018 09:24 PM
turnkyle
08-12-2012 08:44 AM
jay_1
04-04-2000 05:54 PM
