HELP!!
HELP!!
hi everybody.
i have a ford f 700 1994 with a ignition switch broken.
i call a lot of ford dealers and they said the the real one wich is F3HZ-11582-a is discontinued and the one they call it is E6HZ-11582-A wich does not fit.
is anybody knows who or how to get the ignition cylinder switch F3HZ-11582-A?
thank you all.
thank you all.
What year truck? I didn't have any luck searching with your part number (if it was available through a dealer/OEM source, that should pull it up).
This is probably your best bet.
Edit: Strike that...they don't have a F-700 listed.
http://www.car-part.com/
Edit: Is this the part?
http://cgi.ebay.com/ebaymotors/Motor...item35b32ef483
http://cgi.ebay.com/ebaymotors/Ford-...item3cb9cb61df
http://cgi.ebay.com/ebaymotors/NEW-I...item20bbac8701
THANKS ARCHER
thoes web sites i did try before and the funny thing is when i call was a guy with an indian asian accent and he told me that he had in stock the f3hz and asking 3 times to make sure.
when i call back to place an order it was another indian guy wich i ask him to tranfer to the extension # he said that ext does not exist neither the name i got from him.then he tells me that they have 300 people on the shop.so i imagine right away whats goin on also he said that they did not have the right part
thanks for your help.
I have a 1994 Ford F700 with a ignition switch broken.
I call a lot of ford dealers and they said the the real one which is F3HZ-11582-A is discontinued and the one they call it is E6HZ-11582-A which does not fit.
If you have a 1987-1994 F700, E6HZ-11582-A is correct.
Is anybody knows who or how to get the ignition cylinder switch F3HZ-11582-A?
F3HZ-11582-A is not listed for an F700, so...it does not fit an F700!
11582: This is the ignition switch CYLINDER & KEY only .. it is not the ignition switch itself.
1987/94 F600/700/800
D7AZ-11572-A .. Ignition Switch (Motorcraft SW-1379).
E6HZ-11582-A .. Ignition Switch Cylinder & Key (Motorcraft SW-2000).
Are you sure you have an F700? People tend to confuse an F700 with L/LN/LNT/LTS series trucks. If your truck is an L/LN/LNT/LTS, these parts are in-correct.
Post the first 7 digits of your trucks VIN
