Don't laugh but you can free those frozen U-joints.......
Old 08-30-2011, 06:45 PM
EXv10's Avatar
EXv10
EXv10 is offline
4wd front U-joints binding, dry, clacking, causing wheel jerk? , try this; (It works). 1. Go to an empty parking lot with a full can of penetrating oil, turn your wheels to lock, spray joints, go in a circle spray etc etc etc, change directions repeat, repeat, repeat. or 2. Tear a 1' strip of old towel 1" wide, soak it in ATF, run them through you joints and tie the ends so they don't come out and drive like that for a couple days and start by making some tight turns.
My joints were creaking, jerking the wheel big time, etc, 2 years ago and after rejuvenating them with this fix (just took the first one but was slightly better after fix # 2) they have been like new ever since.
Old 08-30-2011, 09:40 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Reps for the tip!
Stewart
Old 08-30-2011, 11:24 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by Stewart_H
Reps for the tip!
Stewart
Thanks Stewart.
Old 08-31-2011, 10:35 AM
Callmed's Avatar
Callmed
Callmed is offline
Def keep that in mind. Thanks
Old 08-31-2011, 02:56 PM
goodmatt2002's Avatar
goodmatt2002
goodmatt2002 is offline
Excellent tip! I was just contemplating how to do the very same thing!
Old 08-31-2011, 06:07 PM
HD RULES's Avatar
HD RULES
HD RULES is offline
No offense man but if you think about a u-joint and it's design, this doesn't make any sense. How does the oil makes it way past the seals?? If perchance it does make it's way past the seals, the same way in is the same way out. If the joint is binding, the needle bearings are more than likely toasted. Time to change it.
Old 08-31-2011, 06:12 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
Agreed.
And I would add that Penetrating oil and ATF would just dissolve what little grease was left on the probably toasted needle bearings.
Old 08-31-2011, 06:59 PM
EXv10's Avatar
EXv10
EXv10 is offline
Not true, and why is mine acting like new afer 2 years? The light oil makes it's way into the dried grease that is still in there and rejuvenates it. Those joints rarely wear out because they get about a tenth of the action of the rear joint but they do dry out which is the demise of them. I didn't just write my fix because I had a weird dream and woke up with the idea.
Old 08-31-2011, 07:05 PM
EXv10's Avatar
EXv10
EXv10 is offline
Originally Posted by ToMang07
Agreed.
And I would add that Penetrating oil and ATF would just dissolve what little grease was left on the probably ? toasted needle bearings.
That's not true either. You guys knock it without trying it and you leave a little yellow guy shaking his head. The light oil adds to the dried grease and rejuvenates it which gives the needles which are still in good shape but dry a new life.
Old 08-31-2011, 07:08 PM
william_04_x's Avatar
william_04_x
william_04_x is offline
Sorry Brent, but this trick didn't work for me.
Old 08-31-2011, 07:17 PM
EXv10's Avatar
EXv10
EXv10 is offline
Worked for me 2 years ago and still working. Maybe you didn't do it right, did you try both methods? If you wait too long nothing will help because the grease has dried to the point where the needles finally wore out and broke up. Also, you can't just give it a shot of oil and do a full circle, you have to work with it about 20 minutes but it sure beat putting new ones in for me. Those joints never wear out with good grease in them because they only get probably a fiftieth of the action of the rear ones but they do dry out and don't require much lube to work well but they won't tolerate being dry for a long time with a lot of action on them.
Old 08-31-2011, 07:26 PM
HD RULES's Avatar
HD RULES
HD RULES is offline
Whatever works for you man.
Old 08-31-2011, 07:33 PM
EXv10's Avatar
EXv10
EXv10 is offline
Yea, don't try it....just put new ones in.
Old 08-31-2011, 07:46 PM
EXv10's Avatar
EXv10
EXv10 is offline
Probably because you have 2 wheel drive.
Old 08-31-2011, 08:05 PM
william_04_x
Dreamkiller...
I see you looked at your rep. LOL
Quick Reply: Don't laugh but you can free those frozen U-joints.......
