Fault Codes found now what?
NEWBIE,
Code 12-RPM unable to reach upper test limit
Code 13-RPM unable to reach lower test limit
Code 21-ECT out ot self test range
Code 16-IDM signal not received
Specs. 1988 EFI speed density 5.0
Early Bronco, w/C4. It runs ok, just trying to ID and fix these codes.
I recently pulled these codes from my scanner. I’d like to know where to go from here.
The RPM seems to be related in most of the faults. Where should I start? Thanks in advance.
Dave
Dave
