Everytime I step on the gas my truck pops
I drive a 1992 ford bronco. I have a 5.8l 351w I recently had trouble with the time and then the alternator. I finally got everything figured out and now there is a popping noise everytime i step on the gas. Im not to sure exactly what it could be. I was thinking maybe it would be an injector, or and bad spark plug/wire. I just need help at this point
What did you set the timing to? Stock is 10* BTDC with the SPOUT connector unplugged. Mines up to 13* with no pre ignition, but I think I may have heard it a little bit the other day when I really stood on it.
Does it sound like spark knock? Is it a pop noise if its in park and you step on the gas? Or just a pop when you step on the gas in drive?
Yeah if it was a bad plug, wire, or injector you'd simply have a misfire, and you don't really hear those. Somewhere on here there are pictures of what the SPOUT looks like, I'll try to locate that thread and post a link.
Edit: You're not one of those dudes that fits my signature are you (doubt it, but just checking)? You do need some exhuast.
maribou912
20
12-01-2011 06:05 PM
gwhpnut
16
01-26-2011 08:04 PM
