Hi. Ive got a 71 f250 leaking oil near the entrance of the dip stick to the oil pan. its the little rectangular plate that is on the oil pan where the dip stick goes in. It looks like you can only get to it from the inside the oil pan. I'm assuming I need a gasket of some sort for this.
I love these old trucks but am a bit of rookie when it comes to this stuff. Any sugeestions.
That piece is permanent it is riveted to the pan. Just spray the area down with brake clean then cover it with Grey High density RTV and all will be good! Also you should pull the dipstick tube and reseal that at the same time.
