i installed an egr delete on my 2003 6.0 put back together and now have no power i get these codes P006a P0603 P1000 have no exhaust leaks ,i can hear the turbo whistle until about 2000 rpms ,it runs fine just takes along time to get to speed and wont pull hardly anything checked map sensor hose it fine did the vgt relearn when at idle can hear the change of pitch the in exhaust any suggestions
Don't you need a re-tune once you do an egr delete? Pretty sure you're throwing off the ECU by deleting the EGR when it still expects it to be there...
Oh, you're not blowing any blue or white smoke are you? Might be coincidence, but mine acted the same way when I had 3 blown injectors...hardly would pull worth a crap but everything else seemed to be fine
well i pulled the solenoid out of the turbo and cleaned it and the truck runs great now all the power is back the solenoid must have been stuck or somthing, thanks for all the help
