what kind of fuel mileage on 7.0L
you might be good at 7 MPG ! What type of truck , flatbed , box , dump ! what all is the truck hauling around , and how much does it weigh ? does it have a auto or manual tranny and the gears in the rear , any idea about the ratio ? our old F700 with a 429 got around 4 MPG it was a old gas company service truck with all tool boxes on it and a built in air compressor , we added 1000 gal tank to it for water and water pumps for drilling , it was geared low for around town use , top speed seemed like 55 mph , slow !
me personally would rather have propane ! do you know if the truck came from the factory set up on propane ? i am going to guess that the gas tank is not on the truck , and it is fuel injected so is the throttle body there or did they replace it for the propane ? and do you know if all of the gas fuel lines were striped off the truck ?
any pictures would be nice if possible !
Truck came from factory with propane, was owned by home propane delivery co. for first ten years until 2005 , then it was stolen . this is a theft recovery truck. only 84,xxx miles. No fuel tanks lines or pump. could i put carb. on it ? Not sure if these things have really high compression, as that would affect its performance on pump gas
in your other post ,
thats around 4 mpg ? probably not out of line !
I have a 1995 F-700 with 7.0L propane engine from factory. i need to know what I have to do to switch it to burn gasoline. The truck runs great as it is but I can only go about 22 miles on a 20 lb. bottle. I know that because I ran out 3 times bringing it home the night I bought it. My gps system showed my route was 66 miles. also Will the high compression of this engine be a problem with regular gas ??
would it be that simple ? no distributer change or anything like that ? i assume there is a plate on engine somewhere for a fuel pump , or maybe an electric one. thanks so much
I've got an F600 w/a 7.0L gas engine. I have a horse van (box) sitting on the chassis, so, that makes it a horse van. The vehicle, a '94, is fairly new to me so I've only taken it on two trips with an 1100lb horse on it. The box probably weighs about 6000lbs with my truck weighing 6700lbs. First trip, I got 7.5 mpg and second trip, one where we got stuck in rush hour traffic and had a few more hills in the mix, I got 6 mpg.
Pretty damn good, according to a friend of mine who has a Hummer H2 and only gets 8 mpg when he tows his fishing boat with it.
