Brake question
Old 08-21-2011, 05:04 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
Brake question
I just finished rebuilding my stock 53 mc and bled the brakes. How much should the pedal travel before you feel it engage the brakes. Should you be able to stand on the pedal and lock the brakes up?
Old 08-21-2011, 10:46 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
You shouldn't have to push the pedal too far before you feel some braking effort. By half way down you should be stopped. I would expect you to be able to lock up the brakes, or darn close, by standing on the pedal hard, panic stop style. From your question, it sounds like you may have a problem?? Just like with newer vehicles, long throw (too close to the floor) or spongy pedal means you have defective parts still or air in the lines. Or, you could just need to adjust the shoes tighter.
Old 08-22-2011, 04:13 PM
Pappys53's Avatar
Pappys53
Pappys53 is offline
It has been awhile since I adjusted brake shoes. Cant ever remember which way you turn the adjuster from the back side. Merc can you tell me which way?
dinikin
1997 - 2003 F150
12-15-2009 06:23 PM
shendoa
12-20-2004 08:55 PM
Fuzion01
10-24-2004 02:27 PM
Rmcmorris
08-25-2004 11:51 PM
Quick Reply: Brake question
