Optima battery?
in my experience the optima batteries are very overrated. i tried one with poor results, warned 2 friends not to get them, and they too had problems. i stick with interstate bats and have no problems. long lasting and very reliable. i have had them in many differant cars with the same positive results.
I won't risk being stuck in the middle of no where using an overrated POS battery. That is just me I have had way to many fail on me and would never ever use them again. I myself only use Johnson Controls batteries. I normally get mine at walmart or through my supplier. Very little failure rate and easy warranty if you need it!!
Did a bit of research a while back and decided on a Die Hard Platinum P-2 ($190) I believe the CCA 930 I can't remember what the old battery was but I know it was quite a bit less. She turns quicker when I turn the key but the real test will be how it reacts with the plow this winter. So far so good though although I have only had it a few months.
zer01
02-25-2015 04:54 AM
diego-ted
03-21-2014 03:16 PM
