EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Ecoboost reliable?
Old 07-31-2014, 10:25 AM
mefast's Avatar
mefast
mefast is offline
Originally Posted by conger
I spoke to my service rep about these concerns and they reply was that it was news to them.
Besides myself, I know people in construction and oilsands work who punish these trucks and they seem hold up well.
I think the key to long life from the EcoBoost engines is to work them hard. Go around to any Ecoboosted vehicle and you'll notice carbon buildup on the tail pipes. Get the engine warm and step on it and it will almost look like a diesel with what comes out of the tailpipe.
The grocery getting vehicles will have problems, but the ones that have fun or tow often will be clean. So go beat on your vehicle! It's a Ford, it can take it!
  #32
Old 08-09-2014, 07:00 AM
crhend's Avatar
crhend
crhend is offline
Basic design does resemble a diesel with forged crank and cross-bolted mains. For the carbon build-up, do what we used to call the "Italian Tune up" Get on the freeway, hammer down and work through the gears occasionally. Driving the kids to school and those short trips to the store are carbon builders in any engine.
  #33
Old 08-09-2014, 10:08 AM
conger's Avatar
conger
conger is offline
Hook it up to something heavy and drag it around town for a couple of hours. This motor likes hard work.
  #34
Old 08-09-2014, 04:04 PM
Tigauto's Avatar
Tigauto
Tigauto is offline
Ha you could hook it up to my 2007 with the POS 5.4 that needs replaced.
That should be enough weight.
  #35
Old 08-10-2014, 06:28 PM
cb_13's Avatar
cb_13
cb_13 is online now
Originally Posted by Tigauto
The Eco boost has problems with carbon build up on valves, fords TSB. It also states that injector cleaning can not been done do to damage to turbos. Part of the reason is for rich mixture on start up. Under warranty for hesitation, misfire ford techs to check for carbon build up if located recommended to replace heads. So on Eco boost if you have or do de carbon flush say good by to your warranty. How in gods name can ford design a engine that can not be survived for carbon build up. Also from what I understand the 5.0 lt is nothing more the a 4.6 bored
The 5.0 is still a modular engine but it is a Ti-VCT 4 valve. That's a far cry from any 4.6 ever offered in an F150. What's the tsb for carbon on the valves? Last I talked to a field service engineer he told me the Ecoboost was not experiencing carbon buildup on the valves like DI engines from other manufacturers. Of course the BG rep told us all about how bad it was and they were gonna quit running after 60k miles if we didn't use their fuel system treatment through the air intake. I had heard that the rich mixture on start up was causing the black soot on the tail pipes that is so common on the eco boost trucks.
  #36
Old 08-10-2014, 06:59 PM
Tigauto's Avatar
Tigauto
Tigauto is offline
Well if you are getting black soot on the tail pipes that tells you what's going on in the combustion chamber. I don't have the TSB with me but there is information from a ford tech on you tube. This explains what is going on and the TSB explains repair. This information from ford under warranty is to replace heads. Combustion cleaner will over heat the turbos causing failure. If you read about the 5.0LT it explains ford is using the 4.6 block with modified heads.
  #37
Old 08-10-2014, 07:09 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
https://www.ford-trucks.com/forums/1...oboost+engines
This may be the thread that you are referring to. It's based on the 2.0L ecoboost, not the 3.5L.
  #38
Old 08-10-2014, 08:42 PM
dkf's Avatar
dkf
dkf is offline
^^ The 3.5l will have those same issues. Same design, DI, EGR and etc. Working the motor hard is not going to cut it and eliminate the problem. Huge oversight on Fords part.
  #39
Old 08-10-2014, 09:27 PM
cb_13's Avatar
cb_13
cb_13 is online now
Yes you are correct on the 5.0. Shares same block design as 4.6. I thought you were implying it was strictly a bored/stroked 4.6 which would be selling it extremely short as there's alot more technology to it than the 4.6. The surprise to me would be ford admitting to a problem with the 3.5 eb. They have alot riding on that engine and I'm sure they wanna keep its reputation as clean as possible. I will say that the only engine issues I ever seen personally from the ecoboosts were cac related. It was rare for one to come in with over 100k miles though.
  #40
Old 08-19-2014, 12:11 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
I know we just came from an Audi 2.0L turbo with Direct injection and they were starting to have issues with carbon buildup....
VERY EXPENSIVE fix for them - and assume there will be the same issues here...
Redrockerstl55
2015 - 2020 F150
01-26-2019 02:48 PM
david ortiz
2004 - 2008 F150
02-14-2016 09:05 PM
385seriesHemi
General Automotive Discussion
11-27-2012 09:35 AM
EdCaffreyMS
2009 - 2014 F150
16
01-12-2012 11:08 PM
Bdox
Ford vs The Competition
18
01-03-2006 04:12 PM
Quick Reply: Ecoboost reliable?
