Replaced the mechanical fuel pump in my 95 7.3 today. Truck ran before but pump leaked and had loss of power. Put the new pump in and truck fired up after a few cranks. I keep the rpms at about 1500 for 5 minutes to get the air out of the system. Let the truck go to idle then it died. Hasn't restarted all afternoon. I'm very confused. I have plenty of fuel. It just won't fire at all. I have no idea what could have went wrong?
If I had money to just **** away I'd replace a lot of things but the fuel pump drained my account. Just trying to get my truck up and runnin again so I can get back to work.
I've got a DMM Ill backprob the connector harness. What color wires is the cmp? I can prolly get a scanner from a friend this afternoon. My truck is scannable. I've used fords IDS system on it and genisus system scan tool. Snapon modus and ethos also work very well.
Well I looked and there's about 6-7 wires in a harness on the front of the motor. It splits to 2 sensors coolant temp sensor and cam sensor. Where the other wires go I have no idea.
