Disc brake conversion for '66
#47
Kirby,
We mounted the proportioning valve at the master cylinder via a Simpson strong-tie bracket available at hardware stores. Keeps the valve accessible and simplifies plumbing. As you can see in these pics we reused the original brake light switch by placing it in a tee feeding the rear circuit. You can put a tee in any of the delivery lines if you want to reuse the original style switch.
#48
First off thanks everyone for walking me through this conversion you guys have really bailed me out. Hopefully you can help with 1 more. The old brake light switch was screwed into the end of the 66 master cylinder. Now how do you tie in the brake lights do you have to attach switch to 66 brake pedal what's the easiest direction to go. Again thanks for everyone's help.
#49
#51
#52
Mark, Not to argue, your friend may know about a particular switch that failed. I can only say that I have been around Slicks since they were new, have been on this site about every day since before the reset date on my user, and don't recall reading about a switch blowing apart.
I freely admit my forgetter works in overtime, just don't recall hearing that before.
John
John
#53
can you send me the link for the parts kit from Master for my 1966 F100 ? I've all the feedback and wow, excellent details on different experiences with donor vehicles. I don't have any space to keep a donor vehicle and i want to use Ford parts so this looks like a really good option. Secondly, if i select the donor vehicle it may have some "iffy" parts. I do want to keep my twin I-beam suspension.
I like this option and would like t see the cost of the kit "including shippin".
Should i spend the $$'s on a long bed? This question is haunting me. Chris
#54
I have a 1966 F100 long bed with a T18 4-speed transmission. I'm thinking about getting a 2003 to 2008 crowne vic as a donor car and putting that front end on my truck. this way I get power disc brakes and power steering. some of the articles are a bit sketchy....what say you all? is it worth it? You can pick up a donor car pretty cheap and if it a pretty straight install it sounds like a good option. There are a few troubling details:
does this conversion "lower" the front end? I don't want it lowered?
Is it reversible? I could save the original twin I-beam parts? should I?
Do I get to use my original steering wheel and column?
does someone have a URL that points to a well documented conversion?
thanks guys. any help hugely appreciated.
jtwhite
09-22-2010 03:41 PM
BorisPalance
04-14-2009 11:02 PM
