1994 4.9 miss/stumble/hesitation/hard start
i have a 1994 e150 4.9L. It recently started stumbling and missing very bad upon acceleration and even throughout all gears. i replaced fuel filter, made the egr restrictor plate. but i put a fuel pressure guage in the rail and i got only about 20 psi when you turned the key, if i tirn it on and off 3 or 4 times i can build it up to about 30 psi. when it starts it stayed at about 35 psi and when i shut it off the psi actually builds slowly to about 45 psi. is the fuel pressure regulator or the fuel pump bad and causing this lean/starving condition? thanks
Richard Olshefski
05-01-2014 06:55 AM
dchough
08-16-2012 01:38 PM
oreodog
07-04-2011 11:01 AM
udder
05-03-2011 07:02 AM
