2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 11-21-2014, 12:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
Print Wikipost
Rear shocks/struts replacement?
Old 08-11-2011, 11:30 AM
berry1234's Avatar
berry1234
berry1234 is offline
Has anyone replaced their rear shocks/struts(which are they?) on their Expy yet? Was it hard?
Old 08-11-2011, 11:51 AM
BlueOvalDude's Avatar
BlueOvalDude
BlueOvalDude is offline
Berry,
The Expedition has shocks in the rear. I've changed out the shocks on a '08 Expedition about 6 months ago and the process wasn't too intensive. It's essentially a standard shock replacement job. For your reference, here's the procedure that I followed:
1) With the vehicle in NEUTRAL, position it on a hoist.
2) If equipped, disconnect the air suspension height sensor connecting link from the lower arm.
3) Remove and discard the shock absorber lower bolt and flagnut. (see Expy shock diagram)
4) Remove and discard the lower arm-to-frame bolt and flagnut.
5) Remove and discard the lower ball joint nut.
Caution: Do not damage the ball joint boot while installing the special tool.
6) Using the special tool 204-592, separate the lower ball joint from the wheel knuckle.
7) Swing the lower arm to the rear of the vehicle and remove the lower arm
8) Remove and discard the upper mount nuts.
9) Remove the shock absorber and spring assembly.
10) To install, reverse the removal procedure and note the following:
Tighten the new upper mount nuts to 30 ft. lbs. (40 Nm).
Tighten the shock absorber lower bolt to 350 ft. lbs. (475 Nm).
Tighten the lower ball joint nut to 111 ft. lbs. (150 Nm).
Tighten the lower arm-to-frame bolt to 221 ft. lbs. (300 Nm).
I think that just about covers it all. Remember to not tighten the lower arm-to-frame bolt or shock absorber lower nut until the installation procedure is complete and the weight of the vehicle is resting on the wheel and tire assemblies
Old 08-11-2011, 11:58 AM
berry1234's Avatar
berry1234
Thanks for the feedback. This is a bit more than I am comfortable with. I have changed the standard shocks-not coil over-many times-two bolts-but this one might be too much for me. Thanks again for the info.
Old 08-11-2011, 12:21 PM
glruff's Avatar
glruff
glruff is offline
Great info Jimmy!
Do you work for Ford or a dealership?
Old 08-11-2011, 04:58 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
it isn't hard, just tedious. I'm too cheap to pay anybody to do it for me.
Give it a try Berry. You're probably looking at $200 in labor alone
Old 08-11-2011, 05:00 PM
berry1234's Avatar
berry1234
Yikes. I have all the tools except the ball joint tool.
Don't I need a spring compressor as well?
Old 01-25-2017, 11:59 PM
k9education's Avatar
k9education
k9education is offline
Originally Posted by BlueOvalDude
Berry,
I've got an '11 EL Limited and I have struts in the rear. Both Ford ESP and the tech at the local dealership argued with me up and down that they were shocks, but once it was up on the lift the tech called me and said: "OK, you have struts in the rear."
Old 02-02-2017, 07:50 PM
Brahms's Avatar
Brahms
Brahms is offline
This
Replace your LLS with steel springs!
https://www.ford-trucks.com/forums/1444256-adventures-with-the-arnott-air-spring-conversion-kit.html
sfc2001
22
05-09-2023 02:36 PM
khadma
1997 - 2003 F150
20
06-16-2010 08:00 AM
madsonp
1997-2006 Expedition & Navigator
12-31-2007 08:49 PM
RangerPilot
1983 - 2012 Ranger & B-Series
09-03-2006 04:11 PM
Quick Reply: Rear shocks/struts replacement?
