3.9L (Freestar) Intake Manifold Runner Control
Old 08-03-2011, 09:51 PM
99expyTN's Avatar
99expyTN
99expyTN is offline
I realize this is mostly trucks, but I thought someone might benefit from IMRC problem. My 2004 Freestar threw code P2004 - Intake Manifold Runner Control stuck open - bank 1. After a little research via google I found a diagram of the IRMC and then found it on my freestar. Below is a picture of the condition it was in:
The bushing was broke. I purchased a new pack of bushings from Advance Auto (dorman 47099, pack of 5, $2.50). I dropped 2 before I managed to get one in the lever. The trick - I wrapped my finger with duct tape, sticky side out, and then stuck a bushing on it. I could just get my finger down there to push the bushing in the lever. I then used needle nose pliers to push the rod into the bushing.
Anyway, maybe this might be helpful to others.
Old 08-05-2011, 12:21 AM
bokker's Avatar
bokker
bokker is offline
pictures paint a thousand words! bokker.
Old 08-05-2011, 08:30 AM
BrianA's Avatar
BrianA
BrianA is offline
+1 ^
Thanks for sharing.
Old 06-19-2012, 01:03 PM
SeabeeO(Ret)'s Avatar
SeabeeO(Ret)
SeabeeO(Ret) is offline
Thanks!
The dealer wanted $350 to replace this IMRC clip. Ever other internet post says clips are available only from a dealer. I called Pep Boys and Advanced Auto and they said the same. It looks like to me that Dorman 47099 bushing you used will work perfectly. I'm currious to know if the bushing has been holding up for you.
Old 08-25-2013, 08:43 PM
99expyTN's Avatar
99expyTN
99expyTN is offline
Never saw this question from 2012, but just to follow-up.......the Dorman bushing is holding up just fine. I replaced it 2 years ago at 94k miles and no problems. Now at 118k miles on odometer
Old 08-18-2014, 12:45 AM
whodeylt's Avatar
whodeylt
whodeylt is offline
does anyone know where the imrc is located on the engine of a 2005 freestar? im getting a code p2006. the pic at the top of this post is an excellent picture but im not sure exactly where it is on engine. thanks
Old 05-14-2016, 02:11 AM
spiralthomas's Avatar
spiralthomas
spiralthomas is offline
IMRC location 05 freestar
[QUOTE=whodeylt;14591852]does anyone know where the imrc is located on the engine of a 2005 freestar? im getting a code p2006. the pic at the top of this post is an excellent picture but im not sure exactly where it is on engine.
it's right in front of the fuel rail on the front of the motor. had a wicked combo of issues, turned out the IMRC bushings/nylon nuts were the real culprits. got some dorman 47099s on the way, hopefully she will be all better. good luck
Buck268
3.8 & 4.2L V6
07-29-2017 08:32 PM
bl2009
3.8 & 4.2L V6
08-18-2016 10:34 AM
compwrench
1997 - 2003 F150
01-16-2012 02:00 AM
big60
1997 - 2003 F150
11-09-2002 07:19 PM
davisr9
1997 - 2003 F150
08-28-2002 08:29 AM
Quick Reply: 3.9L (Freestar) Intake Manifold Runner Control
