Air Pump removal?
Air Pump removal?
It is a 94 F250 5.8 with a C6 behind it. 160,000 miles and the air pump is making noise. I sprayed some WD40 into the intake hose and it quiets it down for a few miles, then starts up again. I do have an eliminator pulley and bracket that I pulled off of another truck...anticipating that one day I might have to do this. I prefer to keep most things close to stock, makes it easier to diagnose and repair, IMO, but I do not really want to drop $100-$150 for a reman/new pump... I live north of KC and have a local shop do my inspections...don't want to ask them, since I know that answer and it would direct attention to my truck. I do 99% of my repairs. My question is: What is the chance that if I remove the pump that I will fail my next inspection...(visual as I don't believe they do sniffer tests on this side of the state) which will be in Nov of 2012. I used to live in Central Kansas, no inspections, so I wouldn't worry about it then...just seeing what those of you in MO think? Cat is gone, it was insides were cracked and in pieces so I went ahead and gutted it out when I had it off to replace my O2 sensor (long story, lots of drill bits, don't ask). Thoughts, opinions? Ideas? Thanks!
Thanks for your input...truck is only used to haul a gooseneck horse trailer...and to drive to and from the barn...so it isnt a DD, but I need to decide what direction I am going to go with it, as I certainly do not want to have the pump sieze/die on us on a 4 hours from home...with the horse in the back. Not a good situation. Thanks again for your quick replys!
Dorsai
08-17-2012 07:14 PM
mark460
15
02-18-2007 03:41 AM
eco
08-20-2006 08:05 AM
