Just bought a factory aux idle controller... have questions..
99 F350, I just bought an auxiliary idle controller. Factory Ford, with the LCD screen, new in box with cable and mounting bracket.
First impression, holy crap this thing is HUGE, much larger than I expected.
Second of all, where under the dash exactly does it mount? It did not come with bolts so I'll have to get some.
Third, there is a plug that goes into the idle controller with 10 wires, but the plug splits and four of the wires run to a 4 pin plug which will plug into my truck under the dash.
The remaining six wires are just cut, and do not have a plug on the end. What do these other six wires do???
Fourth, what exactly is a "Power Take Off" ??????
The plug that is left is the one that connects under the dash right under the steering wheel. The wires that are cut just tape them up. If it came with a mount it goes near the hook on the passenger side or if you have the ash tray. It uses the screws that hold the hook on the bottom.
Yeah I read the manual and those extra wires are for PTO and remote control switches.
I mounted it under the ashtray. It works great, just the thing takes up a lot of prime real estate!
It's so large not sure where else I can mount it, unless I rig it up and stuff it under the dash somewhere....
I'll try it on the ashtray mount for a while and see how that works.
I should have bought the smaller one, that's for sure.
If yours came with the K bracket then it will mount under the dash just to the right of the accelerator pedal (over the transmission hump). Remove the two 8mm screws that secure your lower dash and the bracket will use those same holes. The kicker brace matches a hole that is already pre-drilled on the baffle under the dash (where your trailer brake controller harness plug is secured. The loop on the kicker brace is for securing the 4 wire harness so it doesn't fall down onto your feet while driving.
Like you already figured out, the 4 wire connector connects to the factory installed plug under your steering column. The other wires are for remote control and electrically activated PTO accessories.
Yeah, they are pretty large. I've only seen the one size...do they make a smaller unit?
Here is the manual in pdf in case you would like it for your records.
I would much have it closer to the area than you described. I don't want my passengers messing with it.
Mine only came with a bracket to mount under the ashtray. I didn't know they made another one? Don't happen to have a picture or a part number on the bracket would you?
This may be of help, I know Chase did a ton of research on it when he got his.
https://www.ford-trucks.com/forums/8...ss-switch.html
Funny thing is that I bought the AIC for my wife's truck since she has the PTO trans and I was thinking of utilizing it for an air compressor. Then I learned a little more about what is involved and the pieces and expense and that idea has been put on the back burner....way back....like camping stove in the attic sort of thing.
I've been keeping an eye on our work fleet just in case one of our trucks gets put out of service (blown engine or accident or whatever...) but none of them seem to be showing ANY signs of slowing down or needing to be replaced anytime soon so it could be quite a while before I get my hands on a PTO system from one of our 7.3 trucks.
The two sides are hook and loop. Fuzzy side is the loop, the stiff side is the hook.
Received 3,697 Likes
on
what do they cost these days?
the one in my '97 died and I want one in my '99
