196? n-600
I agree the dark green one caught my eye too.
And I wondered if Michelle would chime in when I heard the color comb you were thinking of for your N600 Central. If she hadn't I'd have pasted a pic of her truck here.
Michelle~ You didn't swap out the Cummins did you? or just photo shopping a "what if" scenario.
N60EUE94241 / WB = 121 / COLOR = C / MODEL = N600 / BODY = 4281 / TRANS = 4 / AXLE = F3A / GVW = 19600 / Cert net HP = 181 / RPM = 3800 / DSO = 870281.
N60 = N600 (gas).
E = 361 2V FT engine.
U = Louisville KY Assembly Plant.
E94234 = 1969 (1967 serial # range: A00,001-B82,000 / 1968 serial # range: C00,001-D82,000 / 1969 serial # range: D82,001-G90,000).
121" Wheelbase.
C = Pure White (Wimbledon White would be COLOR code M).
N600 (gas), 19,600 lbs. GVWR
4281: 42 = Charcoal Black Corinthian Vinyl & Charcoal Black Woven Vinyl / 81 = 81A Standard Cab.
4 = Clark model 280VO 5 Speed Overdrive Manual Transmission.
F3A: F3 = Eaton model 15201 2 Speed Rear Axle / 6.33/8.81-1 / 15,000 lb. Rear Axle Capacity // A = Ford 5,000 lb. Capacity Front Axle.
19,600 lbs. Gross Vehicle Weight Rating.
181 net HP @ 3,800 RPM
870251: 87 = Ordered special by a Body Company / 0251 = Domestic Special Order number.
If you want further info, martiauto.com has all the original FoMoCo specs for 1967/79 vehicles. There is a fee for Marti's services, known within the hobby as a Marti Report.
I woulda decoded this jazz sooner, but "She, who must be obeyed' and I were on vacation in the PNW 7/21-8/7.
GJPilcher
110
02-19-2018 06:27 AM
wardsd
35
01-24-2016 07:43 PM
glovemeister
03-29-2011 11:48 PM
